GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
GX470 -How to Troubleshoot Audio issues
Old 03-06-15, 08:57 AM
mann777
mann777's Avatar
Lightbulb GX470 -How to Troubleshoot Audio issues
Hoping this guide helps GX First owners to resolve Audio issues which are commonly faced,
Old 09-20-16, 06:05 AM
Enuksboy
Enuksboy's Avatar
Hi, i use a GX 470, 2007 model. i recently changed the battery of my car and the CD player stopped working. the radio comes on but the CD player wont play. Could it be the Lens?
Old 09-21-16, 11:31 AM
chiph9
chiph9's Avatar
Try this: Disconnect the battery negative terminal, wait 2 minutes, then quickly reconnect it to ensure a minimum of sparks.
You'll have to reset the auto-windows, the seat memory, and the radio stations afterwards.
Chip H.
Old 11-24-17, 11:00 PM
tartanelya
tartanelya's Avatar
hi! everyone,
need help if any can provide gx 470 '06 speaker wiring diagram from amplifier harness.
thank you so much,
tartanelya
Old 01-08-18, 01:31 PM
69fordf100
69fordf100's Avatar
Originally Posted by tartanelya
hi! everyone,
thank you so much,
tartanelya
Still need diagrams? I may have something that may help
paultom84 (08-19-20)
Old 02-11-21, 09:50 AM
Ozpall
Ozpall's Avatar
Default Sound
I know this is old but I just got a gx470 n no sound coming out of radio, everything works just no sound, I leaning towards amp?
Old 02-12-21, 12:55 PM
chiph9
chiph9's Avatar
If you have navigation, does the voice come out of the driver's door speaker?
Chip H.
Old 04-09-21, 09:02 AM
vingx470
vingx470's Avatar
Default 2003 Gx470
HEllo I'm new to the forum. I recently purchased the gx and I have no volume control. Everything else seems to work like the am/fm channel control. I ran a diagnostics check and everything is ok in blue. I've tried disconnecting the battery cable and checked the fuses. I've been reading about Amp issues. Could the amp be shot and the diagnostic check says it's ok. Any help will be greatly appreciated.
Old 04-09-21, 02:55 PM
chiph9
chiph9's Avatar
No volume, or no volume control?
Chip H.
Old 04-09-21, 03:09 PM
vingx470
vingx470's Avatar
Chip H.
Hello Chip. There is no volume and when I turn the volume **** on the radio the volume does not show going up or down. If I turn the channel ****, that show me changing the channel. Hope that makes sense.
Old 04-10-21, 05:42 PM
chiph9
chiph9's Avatar
There's a good chance the amp is bad. Check the fuse, then look into getting it repaired - there's a firm that advertises on eBay that does it.
Chip H.
Old 04-10-21, 06:07 PM
vingx470
vingx470's Avatar
Chip H.
Ok. Thanks Chip. Quick question. I read on another thread about when you disconnect the battery you have to reprogram the power windows. I can't open the windows from the drivers control. They work at each door. Is this something that needs to be reprogrammed. Thanks so much for the help.
Old 04-11-21, 04:16 AM
vingx470
vingx470's Avatar
I Found a youtube video on how to program the windows. Thanks
Old 04-11-21, 04:17 AM
chiph9
chiph9's Avatar
If you disconnected the battery, you need to reprogram the windows, the sunroof, the memory seats and the radio presets. There is a sticky thread about how to do that.
Chip H.
Old 04-11-21, 04:21 AM
vingx470
vingx470's Avatar
Thank you very much for your help!!
Quick Reply: GX470 -How to Troubleshoot Audio issues
