GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Old 12-15-14, 01:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Wheels & Tires How-Tos
Print Wikipost
clunk when stopping and starting and uneven tire wear
Old 09-08-14, 06:21 PM
ilscott
ilscott's Avatar
Question clunk when stopping and starting and uneven tire wear
I have a 2006 GX470 with 125K miles and have two problems which I think are related.
The vehicle does not come to smooth stop anymore. Just before stopping the car loses smooth braking and shudders a little just before coming to a complete stop. This is followed by an abrupt clunk shortly after stopping - as thought the gear has just dropped into an idle mode rather abruptly, but this is not accompanied by any change in engine revs. Upon setting off, there is also a noticeable clunk shortly after the car has moved a few feet. i.e. it starts smoothly but then goes clunk after about 6 feet. Both of these clunks appear to come from the front right of the vehicle. As usual with this type of problem, it never seems to want to do it when the mechanic is in the car and it took several test drives before he experienced it.
At the same time as this began to happen I noticed very uneven tire wear. The front tires both appear to be wearing down a lot faster than the back ones and the front right is wearing much faster than the front left. All tires are wearing evenly across the tire surface so it is not an alignment problem. I did have a problem with the right front tire losing air pressure and it was run for a couple of months with lower than desirable pressure but this was not enough to trigger the low pressure warning and it didn't show in the wear pattern. I also had new struts fitted as these were frozen. At the same time I replaced the front two tires (just a couple of months ago) and am already seeing noticeable wear on the front right tire.
My garage cannot find anything wrong with the vehicle and suggest that I drive it until it breaks a bit more. Any suggestions anyone?
Old 09-08-14, 07:46 PM
Gene01
Gene01's Avatar
I would suggest that you get a better garage, unless the problem is intermittent. From the symptoms you describe, it should be easy for any competent mechanic to diagnose the problem.
Old 09-09-14, 07:25 AM
chiph9
chiph9's Avatar
Try taking it by a four-wheel drive shop. They should be able to spot if there's something wrong in the driveline.
Chip H.
Heagy80
09-02-18 10:42 AM
BMW7_LS430
Wheels, Tires & Brakes Forum
04-25-18 10:02 AM
sc400123
Suspension and Brakes
08-28-08 08:46 PM
jhp012
12-19-07 08:24 PM
Quick Reply: clunk when stopping and starting and uneven tire wear
