GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
2003 GX 470 V-Belt Tensioner Replacement?
Old 06-27-14, 11:04 AM
mjones1160
mjones1160's Avatar
Default 2003 GX 470 V-Belt Tensioner Replacement?
I just received a Gates serpentine V-Belt replacement kit I purchased from RockAuto. It includes a new V-belt, belt tensioner and idler #2 pulley. I see that the belt tensioner bolt on the bottom appears to be blocked by the generator mount. Do I have to remove the generator just to replace the drive belt tensioner?
The parts diagram in the repair manual (CD) page 14-19 only shows a bolt and two nuts securing it. There are 4 holes for bolts on the new tensioner provided in the kit. There are no tensioner replacement instructions included or in the Lexus service manual. The radiator hose is already a pain to work around. Removing the generator to get to the lower bolt would be another added task.
It seems to this job easily, I would have to drain the coolant to remove the radiator hose as well. Is replacing the tensioner really necessary when the belt is changed. I am already second guessing the belt replacement as there are no major cracks in the belt, just minor age cracks with no chunks missing on the V-grooved side. The vehicle has 104,000 miles on it.
Old 06-29-14, 08:03 AM
ROSCOGX470
ROSCOGX470's Avatar
I would just change the belt and keep the other parts in the event of failure, which unlike the TB belt wouldn't hurt anything.
Willauflex
08-24-19 10:13 AM
Spe3dfreak
IS - 1st Gen (2001-2005)
10-27-16 01:40 PM
ancdmd
04-16-16 07:03 AM
avalon42
03-09-08 06:02 PM
markpaco
Maintenance
07-06-02 07:38 PM
Quick Reply: 2003 GX 470 V-Belt Tensioner Replacement?
