GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
bad luck while changing the spark plugs
Old 04-19-14, 12:22 PM
99suprduty
99suprduty's Avatar
Default bad luck while changing the spark plugs
So its maintenance day on the GX....changed the oil, greased the drive shaft and then start on the plugs.
Taking out the 10mm bolt on the very first cylinder and the f-ing bolt snaps. It was cranked in there really hard and took a bit of effort to break it free, way more than it should have. Tried the next one to see what it was like and I'll be damned if its cranked in there too.
At this point, I think I am going to have it towed to the dealer (Toyota) and let the pros handle it. How screwed am I?
Old 04-19-14, 12:39 PM
2GSKaizen
2GSKaizen's Avatar
Re you talking about the 10mm that holds the coil pack on top of each spark plug? They'll just drill the bolt out and re-tap them, or maybe use a helicoil if the hole is to rounded out after drilling. Shouldn't be a huge deal, but that depends on what they charge you...
Old 04-19-14, 12:44 PM
99suprduty
99suprduty's Avatar
Yea, thats the one. Think I could drive to the dealership without that bolted down? Only have to go about 8 miles and it'll save me a tow.
Old 04-19-14, 01:11 PM
ISFPOWER
ISFPOWER's Avatar
simple problem and yes, no problem driving. no need to tow it.
Old 04-19-14, 01:18 PM
2GSKaizen
2GSKaizen's Avatar
Yeah just drive it for sure, you'll be fine.
Old 04-19-14, 02:15 PM
99suprduty
99suprduty's Avatar
Thanks guys....I'll get it in there next week. Hopefully the damage to the credit card wont be too bad....
Old 04-19-14, 03:01 PM
mrblister
mrblister's Avatar
Sometimes it pays to use impact wrench it puts small bursts of torque which help in loosening a stubborn bolt.
Old 04-20-14, 08:00 AM
jmgraham78
jmgraham78's Avatar
pb blaster....
Old 05-02-14, 01:42 PM
99suprduty
99suprduty's Avatar
all good now....wasnt too bad. Less than $200 and that included them changing the plugs.
Old 05-02-14, 04:56 PM
MichaelD86
MichaelD86's Avatar
Originally Posted by jmgraham78
pb blaster....
I second that, anytime you deal with something that is constantly being heated and cooled use some penetrating lube, cant go wrong with lube. EVER!
Old 08-01-14, 06:54 AM
Birch71
Birch71's Avatar
Man. My dealer quoted me $360. I passed on it and was going to try it myself, or take it to an independent.
Old 08-01-14, 07:11 AM
ROSCOGX470
ROSCOGX470's Avatar
How many miles are you guys changing the plugs at? I have 120k and my truck runs flawless
Old 08-01-14, 07:51 AM
IanB2
IanB2's Avatar
Even long life plugs recommend changing at around 60,000 miles, I'd say if yours are original, they are due.
Mrfouche
02-14-17 08:34 PM
cheerio3
RX - 1st Gen (1999-2003)
02-08-15 11:21 AM
R4a2m0o
07-01-14 06:29 AM
janmy7
10-23-12 04:34 PM
trhs75
13
10-09-07 08:57 PM
Quick Reply: bad luck while changing the spark plugs
