GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Replacement of Trans oil on GX
Old 12-11-17, 01:27 PM
  #136
hochiminh
hochiminh's Avatar
I thought because Toyota WS has a really good reputation for non-racing applications.
Old 01-02-19, 09:55 AM
  #137
kamlung
kamlung's Avatar
last week i sent the truck in to do the trans fluid while they had it for it's oil change...
Toyota dealer advertised the service as $105 but charged me $119 for the drain and fill since they said it's a bigger capacity... when i looked at the invoice, i got charged for 4 qts of ATF... i'm assuming it was probably 3qt and a little to top off... car is at 105k miles and drives like butter... it's cheap insurance to get 10 yr old fluid out for the piece of mind... don't listen to the service adviser if they say it's sealed and they can't do it...
Old 01-02-19, 10:55 AM
  #138
vwynn
vwynn's Avatar
$20 Valvoline max life synthetic - 1 Gallon - Fully compatible with WS... works fine for me and wont break the bank.. Gunna do another 1 gallon change when I get the Transmission strainer and gasket...
Old 01-02-19, 04:15 PM
  #139
ALAN553
ALAN553's Avatar
fyi, there is 12-13 qts in there. The best this change does is maybe gets out dirt in screen or pan..,if you want a “change” they need to flush out all the fluid through the trans cooling lines and replenish with 13 fresh qts...Bosch makes a fluid exchange machine that dealers have.....
Old 01-02-19, 08:27 PM
  #140
deeken
deeken's Avatar
But everyone advises against using the Dealer flush. It could do more damage than good. I personally did 3 gallons of amsoil transmission fluid. Drain the transmission pan, filled, started the car and ran through the gears, turned off then drained the pan again, and did the same steps twice again. It's probably more than good enough. Didn't feel like removing the pan and replacing the filter and gasket. Too much work.
Old 01-03-19, 03:24 AM
  #141
ALAN553
ALAN553's Avatar
a controversial service subject. The dealer I used gave me his take...do the first simple drain and refill early, like between 50-60K and then if you still own the truck do a flush 100 K later. You’ve hopefully gotten debris out on the first refill so that the risk of metal particles getting caught in the lines or trans on the flush are reduced.
Old 01-03-19, 04:08 AM
  #142
Matsui
Matsui's Avatar
I got a complete flush done at my Toyota dealer last year at 140k miles and no issues at all so far. This was the first time the fluid was replaced and the car is running perfect . It is a lot more convenient than drain/fill method and I think much more effective.
Old 01-03-19, 06:58 AM
  #143
kamlung
kamlung's Avatar
i'm used to the honda glass tranny where i would never do trans flushes... i grew up doing 4x drain and fills over a 4 wk interval... it obviously takes longer to get new fluid into the system as it dilutes with the old fluid, but i figure it's a better transition... almost like a water change on a fish tank... since i'm at over 100k miles on original fluid, i didn't want to shock the system with all new fluid...
Old 01-03-19, 08:54 PM
  #144
Skyfox16
Skyfox16's Avatar
So I guess I may have missed something. If I just drain out the three quarts of fluid, why can’t you just add 3 quarts back in and be good to go? If the trans is cold and the fluid is cold wouldn’t it be the same amount?
RockfordRX (01-04-19)
Old 01-04-19, 08:12 PM
  #145
RockfordRX
RockfordRX's Avatar
I agree, Skyfox!
Not sure why it is necessary to do the temp check if you replace the EXACT amount that you drain... Unless it is expected that the tranny fluid level drops overtime (evaporates, gets burned off, etc) and replacing the old with new fluid of insufficient amount may burn up the unit?
I agree that if you measure exact amount you drain with what you refill back, there should be no problem. Any thoughts guys?
Old 01-07-19, 10:10 AM
  #146
vwynn
vwynn's Avatar
Originally Posted by RockfordRX
I agree, Skyfox!
maybe that might work if you temperature match your fluid to the fluid temp of a cold car? But honestly its not hard to do the A/T TEMP mode.
Ill be doing mine again so ill create a video. This time around ill be changing out the transmission screen as well and checking the magnets on the pan.
Valvoline MaxLife~!
The following 2 users liked this post by vwynn:
ipaniwala (01-17-19), RockfordRX (01-08-19)
Old 01-17-19, 12:28 PM
  #147
ipaniwala
ipaniwala's Avatar
Valvoline MaxLife~!
Can you do a quick video on the A/T TEMP mode ?
I am getting ready to do mine this weekend and it would help me greatly.
My Transfer case has leaked so we would looking to fix that at the same time too.
Using Valvoline MaxLife for Tranny and Valvoline 80W-90 Gear oil for Transfer case.
Old 01-18-19, 08:26 AM
  #148
vwynn
vwynn's Avatar
Goodluckk on your transfer case leak fix excursion!
ipaniwala (01-18-19), RockfordRX (01-18-19)
Old 05-21-19, 11:26 AM
  #149
lukasbasic
lukasbasic's Avatar
what type of ODB tool will read the ATF temp?
product link appreciated
Old 06-03-19, 03:56 PM
  #150
lukasbasic
lukasbasic's Avatar
so after a long search, I found a relatively cheap way, to read the atf oil temp via the ODB interface.
1. bluetooth ODB scanner (
https://www.amazon.com/gp/product/B005NLQAHS/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B005NLQAHS/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
) - i'm sure other will work too
2. Fusion ODB app (https://www.obdsoftware.net/software/obdfusion) via google play store / android - 5 USD
3. Lexus /Toyota 2006 extra package (inside Fusion ODB (10 usd)
I also tried Torque app, and while it technically can read ATF temp, you need to know the special PID and some conversion formulas, which I was not able to find.
which gives a total of 37USD for some more advanced ODB data, not bad overall I think.
Quick Reply: Replacement of Trans oil on GX
