GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Help.. how to bleed rear brakes
Old 03-19-14, 11:50 AM
Jeeparn
Jeeparn's Avatar
Default Help.. how to bleed rear brakes
Sorry if this is posted somewhere but I have looked (likely missed it due to all the in changing the rotors and pads.)
Anyways; is there a special process needed for bleeding the rear brakes? I can get the fronts to bleed as normal, but only got one 'spurt' out of the rear driver side then nothing.
On a side note, the rears seem to be working as the new rotors are not new looking anymore and a quick touch after a short drive led to a semi-burnt fingertip.
Called stealership and they offer a brake flush for $160 and said they have to hookup a computer to get it to work.
Anyhelp would be appreciated-
Old 03-19-14, 12:54 PM
RCsGX
RCsGX's Avatar
You let the system pump the fluid out for you.
(b) Rear brake lines
(1) Turn the ignition switch to the ON position and depress
the brake pedal.
(2) Connect the vinyl tube to the brake caliper.
(3) Loosen the bleeder plug and release air.
HINT:Brake fluid is sent through the pump, so keep the brake pedal depressed until the air is completely bled out.
(4) When the air is completely bled out of the brake fluid
through the bleeder plug, tighten the bleeder plug.
Old 03-19-14, 03:52 PM
Jeeparn
Jeeparn's Avatar
Once again you saved me. Thanks.
Btw, ok to do this for a good bit on each caliper as to flush out old brake fluid? Reason I ask is that the little that came out of that one rear caliper was rather dirty.
Old 03-19-14, 04:38 PM
burny
burny's Avatar
yes do it until it comes out clean and keep the reservoir full up
Old 03-19-14, 04:50 PM
RCsGX
RCsGX's Avatar
Yeah that's what most do when the talk about doing a flush. Really they are just doing a long bleed to push the old fluid out and get fresh fluid from the reservoir back to the caliper(s). Make sure you keep the reservoir full or else you'll have to bleed the master which I believe you need the techstream to do.
Old 03-19-14, 05:06 PM
Jeeparn
Jeeparn's Avatar
Thanks RCsGX and burny, I'll do this, this weekend and then should be all set for spring break trip.
Old 03-19-14, 06:01 PM
RCsGX
RCsGX's Avatar
Old 03-22-14, 06:52 PM
Jeeparn
Jeeparn's Avatar
All set. It worked just as you guys said. Thanks again
Fpan87
RX - 3rd Gen (2010-2015)
18
09-07-23 08:14 AM
yauny
SC- 1st Gen (1992-2000)
11-18-16 02:54 PM
semar
08-23-15 07:46 PM
qwerty04
Suspension and Brakes
09-21-12 12:16 PM
koody
07-27-11 02:41 PM
Quick Reply: Help.. how to bleed rear brakes
