GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Old 12-12-14, 03:37 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
Rear Shock Replacement With Toyota 4Runner OEM Replacements
Old 07-28-14, 07:51 AM
  #46
erictabor
erictabor's Avatar
Originally Posted by 470SNC
oh one thing to keep in mind 07-09 fj compatible rear shocks work, the 2010 and up FJs had a different size mounting hole at the bottom of the shocks
Does it matter what year the FJ is in regards to the rear coil springs?
Old 08-02-14, 04:42 AM
  #47
sprocket
sprocket's Avatar
My 04 GX with 95K's ride could use a little freshening up. I'm not skilled enough to replace the rear shocks myself. If I wanted to use the OEM 4-Runner shocks, given the issue with widening the lower bracket, where should I take it? If RC'sGX was interested I'd pay him to do it since he is near me. Will a Toyota dealer do this considering the minor custom work needed?
Old 08-05-14, 07:39 AM
  #48
2OnyxLexus
2OnyxLexus's Avatar
you can use any aftermarket FJ/4runner rear shock, I plan on installing my Icon VS2.0s, thanks for the write up, seems straight forward and at most a 30 minute job a side
Jus wondering how your icon shocks are working. How's the feel.
Old 08-31-14, 09:39 AM
  #49
Tact
Tact's Avatar
I just replaced my worn out OEM shocks this morning with the Toyota shocks. Rides like a new car.
Old 08-31-14, 11:28 AM
  #50
470SNC
470SNC's Avatar
The springs are the same 07-current
The icons are nice and smooth, I had them on the FJC and they work absolutely excellent even through big whoops in the sand dunes at Pismo.
Old 08-31-14, 04:36 PM
  #51
2OnyxLexus
2OnyxLexus's Avatar
thanks for the input. the oem toyota shocks worked good for like a week and then the ride got really bouncy and seems like there is excessive sway too.
Old 09-05-14, 09:37 AM
  #52
BlairC
BlairC's Avatar
This is a really great thread guys.
I have 115K on the clock and the suspension is starting to feel really funky.
While I hate the idea of having a switch that doesn't work in the cabin, the cost for the Lexus OEMs is just too much to stomach.
Old 09-05-14, 01:49 PM
  #53
Nothnghead
Nothnghead's Avatar
You can get a blank or pocket from your dealership that will fill that spot (from the 100 series LC's) and no one will ever know.
Old 09-05-14, 02:12 PM
  #54
470SNC
470SNC's Avatar
https://www.clublexus.com/forums/gx-...ilovers-2.html
post 18 has the parts numbers for the blank/pocket that replaces the height control switch
Old 04-11-16, 05:39 PM
  #55
tomtbone
tomtbone's Avatar
Any updates regarding the longevity of the 4runner shocks and/or ride comparisons to kyb or 4600? I am starting with rear shocks and moving to fronts soon.
Old 09-22-16, 11:01 PM
  #56
russellsua
russellsua's Avatar
Default not bouncing ride anymore on lexus gx470
hello there
i had on left side driver side bouncing ride and i think the problem was the shock abrosber its too old, its has 145.000miles already
so i was looking on forums so i decided and bought shocks for Toyota 4runner 2003 (4.7L engine 4wd)
so just bought the new shocks today (22 of september 2016) and installed by me in parking lot, took me 1 hour for total job, used 1 wranch even i did not take the tires out its no need for this,
you will do it easy without taking the tire out
so i bought this new shock absorber for toyota 4runner 2003 from AUTO-ZONE(you can call dealer toyota will cost 50$) parts store cost me 45$ each one total cost with taxes for 2=98$
easy instalation
the oem cost 900$ for bought at lexus dealer or ebay store
so its a big difference 95$ vs 900$
yes you loose ability for sport and comfort regime but who cares never used sport one
and i will to rebuild for oem old rear shocks, will cost 200-300$ and 50.000mile warranty on them
good luck
any question write on site
Old 10-30-16, 07:56 PM
  #57
IMXCITD
IMXCITD's Avatar
Hey guys,
my wifes GX has been riding rough and needing new shocks. We didn't want to spend oem money ...so she has been living with it. Last week....I think her air ride failed. The rear is jacked up and locked in this position. So...after some research I am going to replace the rear shocks and not use the air system any more and go to coil springs in the rear. This will cost me about 380 in parts and about an hour or two of my time. Just wanted to share in case anybody runs into this issue.
Old 10-31-16, 04:46 AM
  #58
Lac
Lac's Avatar
IMXCITD:
Would you share with us all the parts needed on this project?
Thank you.
Old 11-06-16, 08:01 AM
  #59
mrcr0603
mrcr0603's Avatar
I know it's been a couple of years but can you describe what you found out with your situation and how you resolved it?
Thanks!
Old 07-16-17, 06:11 AM
  #60
Butcherpen
10th Gear
Butcherpen's Avatar
Default Rebuild OEM Shocks?
Where do you send them to get rebuilt?
Quick Reply: Rear Shock Replacement With Toyota 4Runner OEM Replacements
