GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Inner Tie Rod/Wheel Alignment Issue!!!
Old 01-08-14, 07:52 AM
kwash703
kwash703's Avatar
Exclamation Inner Tie Rod/Wheel Alignment Issue!!!
Lexus: GX 470 2003
I went to go get a wheel alignment (when driving my car starts drifting to the left hard/ also when my hands aren't on wheel) and they discovered that my front left tie rod is wobbly (also said lower ball joint is suspect). I was told they couldn't perform a complete wheel alignment until fixing the front left tie rod first.
Overall to fix/part/wheel alignment, the quote is
Labor: 223.97
Parts: 71.13 (I seen online for about 50 dollars cheaper??)
ENVIRO/DISPO: 23.61
Sales Tax: 5.68
Total: 324.39 (After 40.00 coupon)
Is this a good deal or anyone know anyplace with better prices? I'm located in Northern Virginia.
Old 01-08-14, 10:58 AM
RCsGX
RCsGX's Avatar
Originally Posted by kwash703
Lexus: GX 470 2003
Labor: 223.97
-Those are NOT OEM parts, just so you know.
ENVIRO/DISPO: 23.61
Sales Tax: 5.68
The labor seems a little high. Even if labor was $100 per hour, it's not going to take over 2hrs. to replace an inner tie rod. I guess if the alignment is adding it, it's not that bad. A non-dealer alignment shouldn't be any more than $50-$60, so if you're fine with paying that cost, do it.
**Driving with a damaged tie rod is dangerous to not only you but others around you on the road. Get it fixed ASAP!
Old 01-08-14, 12:38 PM
470reasons
470reasons's Avatar
Yeah, get that fixed ASAP! A bad ball joint can get you killed. Or at the least very embarrassed when a wheel folds in/out. You could try some other shops for a better price, but don't drive very far or very fast! Your price quote does not seem out of line if the shop does QUALITY work and uses QUALITY parts. Any on-line reviews on this shop or other shops in your area?
If you are mechanically inclined, you could buy a good set of 'pickle forks', a 2 1/2 pound hammer, the tie rod ends and ball joints and do the job yourself. Then bring the truck in for an alignment. (Moog makes very good replacement ball joints and tie rod ends.)
I did a complete front end overhaul on my Honda CRX. Alignment shop told me they don't usually work on cars with owner replaced steering parts, but they'd take a look. Long story short, they DID do the alignment and the shop owner offered me a job (no thanks).
Old 01-08-14, 08:10 PM
kwash703
kwash703's Avatar
Yea I'm gonna get the new tie rod and wheel alignment in the morning!
Old 01-09-14, 12:42 AM
YoshiMan
YoshiMan's Avatar
Steering parts are actually fairly simple to replace, Especially on Rack and Pinion systems like ours. As long as you own a few of the basic cheap tools needed, a tie rod could be done in less than an hour easily
Old 01-09-14, 06:42 AM
chrisvr6
chrisvr6's Avatar
Thats what i paid.
tradosauru
11-21-16 11:09 AM
billydpowe
04-27-15 05:15 PM
maximakid
03-11-13 04:48 PM
lexusben
08-30-11 03:06 PM
element51
01-10-06 07:22 PM
Quick Reply: Inner Tie Rod/Wheel Alignment Issue!!!
