GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
LEDs
Old 11-02-13, 08:03 AM
RCsGX
RCsGX's Avatar
Default LEDs
EXTERIOR
Parking Lights (194 Base) = I'm not using these I just put them in to see how they would look
• Philips : 4000K / pure white
click --->
LINK LINK
Side Steps (194 Base)
click --->
LINK LINK
License Plate (194 Base)
• VLEDs : 5000K / pure white
click ---> LINK
Comparison
Output : Much brighter than stock
With the stock bulbs you can't even see the word Lexus on the sill plate.
INTERIOR
Glovebox (74 Base)
• Superbrightleds : 3300K / warm white
click ---> LINK
Front Roof Map Lights (BA9 Base)
• Superbrightleds : 2900K / warm white
click ---> LINK
2nd Row Roof Light (DE3175 Base)
• Superbrightleds : 3100K / warm white
click ---> LINK
3rd Row / Cargo Roof Light (DE3175 Base)
click ---> LINK
Door Panel (194 Base)
• Superbrightleds : Red
click ---> LINK
Center Diff Lock Switch (3mm Neo-Wedge Base)
click ---> LINK
RSCA Switch (3mm Neo-Wedge Base)
click ---> LINK
Stock
LED
-I forgot to adjust my cameras white balance settings. The output is not this white in person.
Stock
LED
See the attached PDF bulb guide.
File Type: pdf
Old 11-02-13, 05:25 PM
zeeshan66
zeeshan66's Avatar
I definitely want to do this. Since I've never messed with LED is there an conversion or is it plug and play?
Old 11-02-13, 06:24 PM
RCsGX
RCsGX's Avatar
It's all plug and play. Remove your old bulbs and put in the LED bulbs.
Old 11-02-13, 07:35 PM
zeeshan66
zeeshan66's Avatar
GREAT! I can't wait to try this!
Old 11-07-13, 10:54 AM
RCsGX
RCsGX's Avatar
Had an extra pack of the Philips so I tried the parking lights out today. Pics added up top....
Old 11-07-13, 03:46 PM
YoshiMan
YoshiMan's Avatar
Do the LED lights still do the "theater dimming" when you open and close the doors?
Old 11-07-13, 04:15 PM
RCsGX
RCsGX's Avatar
They do.
Old 11-07-13, 06:08 PM
gxman1
gxman1's Avatar
LOVE IT,
How much in LED did it cost you so far?
How do you remove plastic lens and change bulb on the step board?
Old 11-08-13, 05:45 AM
RCsGX
RCsGX's Avatar
Originally Posted by gxman1
LOVE IT,
Yeah they make a huge difference.
So far they cost about $60. I haven't done all of the interior lights but the ones I did are the only ones I needed to be brighter.
You don't remove the lens. Look underneath of the boards and you'll see the sockets. You change them out just like you would a normal 194 bulb, twist the socket remove / replace the bulb and twist back. You'll probably need a shop light because it's a tight fit to get your hand in here. You can pull back some on the running board cover to make it easier to see the socket.
Old 11-08-13, 07:53 AM
gxman1
gxman1's Avatar
Thanks,
just noticed both FOG lights are not working, didnt know it before.
I checked the fuse in the engine bay labelled "Fog" and also swapped with a another fuse, no luck.
How can both be out? Anyway, looks like I dont have to remove any plastics, it has access. Any recommendation on bulbs, I might as well some long lasting bright ones. I would like to buy locally since I want to be done with it. I saw in your PDF shows H3.
BY THE WAY, there are no indication for fuse light on Dash cluster, in my other lexus, if bulb goes out, it shows on the instrument cluster.
Old 11-08-13, 10:57 AM
RCsGX
RCsGX's Avatar
Thanks,
That's weird that both bulbs are out but it is possible.
It's easy to remove the fogs. There's only 1 bolt holding them in from the back then you push it out from the back and pull it out from the front.
See attached PDF and start w/ # 6. I don't know why Lexus says to remove the fender liners and bumper cover. It literally takes 10-20 secs. to remove them. No wonder they like going by the book hours!!
I use standard H3 bulbs from Autozone, O'Reilys etc. I've always liked yellow fogs so I installed some Lexus yellow glass capsules. Now I can run a standard bulb instead of the more expensive yellow bulbs.
Yeah, I don't know why the GX didn't come w/ bulb out warnings?
File Type: pdf
Old 11-08-13, 11:02 AM
thx10
thx10's Avatar
Okay.
So it is my understanding that, after reading this thread, they are direct replacement bulbs. Just find the bulb number and instead of replacing the bulb with an incandescent you replace it with a LED.
No other modifications needed.
Thanks
Old 11-08-13, 11:06 AM
RCsGX
RCsGX's Avatar
Originally Posted by thx10
Okay.
Thanks
Yep, 100% PNP (Plug-n-Play) bulbs. Remove stock bulbs, install LED bulbs.
Old 11-08-13, 11:10 AM
thx10
thx10's Avatar
Nice.
Thanks
Old 11-08-13, 11:17 AM
RCsGX
RCsGX's Avatar
Nice.
Thanks
No problem.
Quick Reply: LEDs
