GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
How to initialize Power Windows - GX after battery Replacement or Reset
Old 09-15-13, 11:11 PM
mann777
mann777's Avatar
Lightbulb How to initialize Power Windows - GX after battery Replacement or Reset
Gents
I am seeing lot of members asking the same repeat question on the Initialization of Power Windows on GX 470 - First Gen
I thought I could give it the illustrative way , That would make it more easier to all who aren't aware.
Hope this helps.
Attached Thumbnails How to initialize Power Windows - GX after battery Replacement or Reset-power-windows-initialisation-1.jpg   How to initialize Power Windows - GX after battery Replacement or Reset-power-windows-initialisation-2.jpg   How to initialize Power Windows - GX after battery Replacement or Reset-power-windows-initialisation-3.jpg
The following 13 users liked this post by mann777:
Carmello (08-29-23), deltron2023 (01-30-24), dtaylor (05-18-17), Frey (07-24-18), JimboVA (10-12-17), JTiger2010 (03-21-24), kupeaholic (03-12-23), Leighm (04-24-19), Matt3400 (12-24-21), MDSteamer (09-11-20), PatrickZh (10-21-20), RoccoL (07-03-23), scmcna (01-21-24) and 8 others liked this post. (Show less...)
Old 11-05-13, 03:29 AM
Fluid
Fluid's Avatar
Thx for the tip; nice to see little tricks like this as people don't always read manuals for common activities like battery changes.
Old 11-13-13, 01:21 AM
EricGX
EricGX's Avatar
Thanks for the tip. I have had issues with my previous battery so I had become quite proficient at doing this. Self-taught unfortunately.
By the way, does anyway know the recommended battery capacity for GX 470? I put 95 amp.
Old 01-28-14, 08:48 PM
dpamoah
dpamoah's Avatar
Thanks for the tip. I've been struggling to get this done.
Old 01-29-14, 03:28 PM
Tipler
Tipler's Avatar
thanks for the tip ,
Old 02-24-14, 08:38 AM
llebcire
llebcire's Avatar
Great tip!
This is also the same process for the sunroof that will lose the auto open/close functionality once power is lost. Most vehicles on the market with auto open or close functionality use this process.
-Eric
Old 04-04-14, 09:29 AM
htbotdvr
htbotdvr's Avatar
Default battery window
thanks IM just a rookie
Old 04-27-14, 06:58 PM
Sethro
Sethro's Avatar
Thanks for this, I just changed my battery
Seth
Old 05-04-14, 06:48 PM
IanB2
IanB2's Avatar
I've been able to get the driver's side window and sunroof to work, but none of the other windows will roll up or down since I had the battery disconnected, what am I missing here? Power window lockout button is not engaged.
Old 05-05-14, 06:21 AM
chiph9
chiph9's Avatar
You're doing it on the affected doors, not on the driver's panel, right? Because the switch assembly in each door is actually a microcontroller that talks to a sensor on the window motor. And it's what has to be reset.
Chip H.
Old 05-05-14, 08:34 AM
IanB2
IanB2's Avatar
Chip H.
Ah, that's what I was missing, thanks! I was trying to do it all from the driver's door switches.
Old 05-05-14, 03:10 PM
IanB2
IanB2's Avatar
That did it, thanks again!
Old 08-25-14, 10:56 AM
MikeI
MikeI's Avatar
Worked like a charm, thanks all!
Old 03-11-16, 06:00 PM
KnooBee64
KnooBee64's Avatar
Default Sos
HELP....
I had my 2005 GX 470 in the shop (not a Lexus Dealership) for a timing belt/synthetic trans/oil. Apparently, the mechanic needed to disconnect the battery for the belt replacement. When I was driving it home this afternoon, I noticed the seat memory buttons were not working. Also, the passenger front and driver rear window would not operate.
I tried Mann777's directions to a "t" and it didn't work. I saw no flashing light on the switches while attempting. I'm wondering if a fuse blew when the battery was hooked back up?
Looking for some possible answers.
Thanks
Paul
Old 03-14-16, 12:38 PM
chiph9
chiph9's Avatar
When the battery is disconnected, not only do you lose your stored radio stations, but you lose the seat memory too. Just readjust the seat & steering wheel, then save the positions.
For resetting the windows - you have to be at the affected door. Left rear door? That's where you need to be to set it.
Chip H.
Quick Reply: How to initialize Power Windows - GX after battery Replacement or Reset
