GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
'04 GX Tire Pressure Alarm
Old 08-24-13, 10:08 AM
ZoeZhe04
ZoeZhe04's Avatar
Default '04 GX Tire Pressure Alarm
We had this alarm for about a month now. I check each tires and the spare are okey. So, it could be a bad sensor. But, how could I know which tire had the bad sensor? Help!
Old 08-24-13, 11:49 AM
Booyah
Booyah's Avatar
Gonna have to take to toyota and use the laptop to see what sensor is bad--bout the only way to do it. I Think they have some sort of battery in them too
Old 08-24-13, 12:10 PM
Crispy3M
Crispy3M's Avatar
If you are interested, there is a good post on here with directions on how to disable your "Low Pressure" sensors.
I have two sets of tires and rims and only the summers have the sensors. I looked up the price of the sensors and decided to just disconnect them instead. Took about 10 minutes.
Cheers!
Old 08-25-13, 05:45 AM
RickC5
RickC5's Avatar
Before you mess around looking for a bad sensor, try this: Inflate ALL FIVE tires to a minimum of 35 pounds at the same time--yes, pull that spare out so you can inflate it at the same time as the other four--then wait a couple of days to see what happens as you drive the truck. This may work. If not, you haven't spent any money, just a little time.
Old 08-25-13, 07:13 AM
IanB2
IanB2's Avatar
It's likely the spare that's low, but I'm another guy that simply disabled the TPMS system on our truck, hate those nanny electronics.
Old 08-26-13, 07:59 AM
BurgBoxstr
BurgBoxstr's Avatar
With an '04, and assuming orig sensors, one or more likely has a dead battery. Most TPMS sensors are designed to have a 4-5 yr battery life... though in my experience Toyotas last longer than most others.
Any decent tire shop can use a handheld scanner and tell you if each sensor is transmitting or not & w/ an '04, replace them much cheaper than at the dealer (may not have to dismount the tire either - just break bead if you have OEM 17" rims).
Good luck
Old 08-28-13, 06:31 PM
ZoeZhe04
ZoeZhe04's Avatar
Thanks to all your suggestions. I will go to tire plus and they will troubleshoot which is which.
Old 08-28-13, 11:06 PM
Booyah
Booyah's Avatar
Great move--better than disabling the "Safety" system
Old 08-29-13, 02:06 AM
ALAN553
ALAN553's Avatar
I have an 04, no TPMS, I thought that started in 05?
Old 08-29-13, 08:38 AM
Crispy3M
Crispy3M's Avatar
Default Tpms
Perhaps it depends on the month it was made?
I have an 04 with the TPMS "Safety" System
First thing I disabled.
Cheers!
Old 08-29-13, 10:36 AM
RCsGX
RCsGX's Avatar
Old 08-29-13, 01:44 PM
ALAN553
ALAN553's Avatar
Cheers!
Ah, mine was made early in the model year, purchased November 2003
Old 09-24-13, 09:31 AM
ZoeZhe04
ZoeZhe04's Avatar
Update, tireplus checked all tires, sensors and all are good. They reprogrammed the sensors and done.
Old 12-03-13, 06:09 PM
UpStarr
UpStarr's Avatar
Is their a beep associated with the tpms icon or is it simply an icon that comes on?
Old 12-03-13, 06:49 PM
RCsGX
RCsGX's Avatar
No beep.
Says I need 10 characters so akldfjlkdajfl;djfladsjflk;adsjlfj
Quick Reply: '04 GX Tire Pressure Alarm
