GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Rear wiper arm removal
Old 05-04-13, 03:47 PM
IanB2
IanB2's Avatar
Default Rear wiper arm removal
I need to change the rear wiper arm as it's broken, removed the cover, and the nut, but there's some corrosion where the arm goes over the bolt, and the arm won't slide off over the nut, it's seized. I scraped the gunk off the base of the bolt and soaked it in WD-40 (the one for getting rusty bolts broken free), and it wouldn't budge. I folded up some shop towel and used it to leverage a trim removal tool underneath the arm to push it out from behind, and even tapped the bolt with a hammer while forcing from behind, still nothing. At this point I was getting concerned about smashing the rear window out of the tailgate, so I packed it up and called it a day.
Anyone have any ideas to get this seized on wiper arm off?
Old 05-05-13, 07:55 AM
IanB2
IanB2's Avatar
I'm going to try a 2-jaw puller, that should do the trick.
Old 12-20-13, 06:40 AM
Muz
Muz's Avatar
I have the same problem. Did you find a solution?
Old 12-20-13, 06:45 AM
IanB2
IanB2's Avatar
It was seized on there, ended up having to cut it off as I was replacing the arm anyways. It wasn't pretty, be careful you don't cut the rubber boot.
Old 02-01-20, 11:05 AM
LGuapo
LGuapo's Avatar
I borrowed a tie rod end remover from Autozone. It worked like a charm.
Old 02-03-20, 07:42 AM
borgunit
borgunit's Avatar
I'll keep that in mind. Good tip.
KC95SC400
Suspension and Brakes
20
04-14-22 07:41 AM
Returd
08-15-17 06:10 PM
DA51
09-01-16 12:06 PM
GS4001999
08-11-13 10:12 AM
kit cat
10-30-09 07:44 PM
Quick Reply: Rear wiper arm removal
