GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Rear Wiper Blade
Old 04-28-13, 04:30 PM
GadgetRick
GadgetRick's Avatar
Default Rear Wiper Blade
Trying to locate the correct rear wiper blade. When I look in the books at the stores, it doesn't list a wiper blade. I'm wondering if it's like my Land Rover where you have to buy a super expensive wiper blade for the rear.
Where can I get a new blade for the rear?
Thanks.
Old 04-28-13, 05:05 PM
IanB2
IanB2's Avatar
From the dealer, and it's actually very reasonably priced. It's actually just an insert, and I want to say it was around $12 or so.
Old 04-28-13, 05:13 PM
trickrx330
trickrx330's Avatar
i measured mine 14 inches bought one at walmart $5 slid the blade out of mine slid the new one out of the anco from walmart and slid it into mine and works fine oh yeah mine is 05 rx not gx just giving example of what i did
Old 04-28-13, 05:32 PM
fishhuntnc
fishhuntnc's Avatar
I got a new rear wiper blade at Autozone. They carry Trico which makes exact fit rear blades. Part #16a for my 2005 GX which is 16 inch. $10 and looks exactly like the one that came off. I'm happy with it.
Old 04-28-13, 10:42 PM
schan1w
schan1w's Avatar
The Lexus wiper inserts are only about $10 also. Not sure I get the idea of going aftermarket here. Note the insert rubber is replaced, not the wiper itself, which is quite a bit more than $10.
Old 04-29-13, 03:54 AM
GadgetRick
GadgetRick's Avatar
Thanks.
Not saying I have to go aftermarket. I didn't realize the price was reasonable. On my Rover, it's like $45ish for a rear blade replacement.
Old 01-04-14, 08:41 PM
Enzoxyz
Enzoxyz's Avatar
Did the same thing so easy!
Old 03-16-14, 12:00 PM
irishbrahm
irishbrahm's Avatar
Thanks for the info on the Trico 16A exact fit rear blade. I bought one for $9.99 at O-Reilly Auto Parts and made the replacement. It took about 5 mins. It works perfectly -- no more streaking and squealing from the rear wiper!
Old 03-18-14, 07:01 PM
eburggx470
eburggx470's Avatar
1) 16” worked fine. 16-A had the proper connection.
Old 03-18-14, 07:03 PM
eburggx470
eburggx470's Avatar
2) Pop the cover off the base of the arm. There is a tab that goes down in between the wiper arm and the assembly. This tab probably keeps the arm from lifting up off the glass. It’s also why when you pull back on the blade it only lifts a little bit off the glass. I accidentally broke the tab off and had to pull it out with pliers. I put the tab back in when I finished since it probably does keep the arm from lifting up due to wind or debris. Not sure how to remove the cover without breaking the tab. Be more careful than me I guess.
Old 03-18-14, 07:04 PM
eburggx470
eburggx470's Avatar
3) See the tab broken off in there.
Old 03-18-14, 07:05 PM
eburggx470
eburggx470's Avatar
4) Pull the arm back. It will lock out.
Old 03-18-14, 07:06 PM
eburggx470
eburggx470's Avatar
5) Rotate the blade
Old 03-18-14, 07:07 PM
eburggx470
eburggx470's Avatar
6) Continue to rotate the blade. When it stops you should be able to just pull it out.
Old 03-18-14, 07:10 PM
eburggx470
eburggx470's Avatar
7) Here's what the end of the arm looks like.
Quick Reply: Rear Wiper Blade
