GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
front axle boots
Old 03-28-13, 06:55 AM
froger1664
froger1664's Avatar
Default front axle boots
has anyone changed the front axles boots yet. Just discovered my inner driver side boots cut open.Is it a DIY or a dealer job. Pls reply
Old 03-28-13, 07:54 AM
danmm7
danmm7's Avatar
I did it by myself. Not that hard at all. Took me 2.5hrs for the driver side.
Buy the OEM boots kit from a Toyota dealer. (FJ Cruiser part number is a match). Get some vinyl/rubber gloves.
You may want to go to auto-parts store and rent the axle nut socket. This is the only "custom" tool you need.
Old 04-10-13, 08:18 AM
froger1664
froger1664's Avatar
Thank you for taking the time to reply. I was away for two weeks, sorry for not replying to you sooner. Would you happen to have the part number the FJ uses. Thanks
Old 04-12-13, 04:50 PM
lsy
lsy's Avatar
Had the right side replaced by a local mechanic for under $250.
Old 04-15-13, 09:39 AM
danmm7
danmm7's Avatar
If you go to any Toyota dealer, they'll give you the part numbers.
I able to find the Driver side boot kit part number. Just go and ask for it.
04427-60140
And to make life even easier, you can even get it from Amazon ($36):
http://www.amazon.com/Toyota-Genuine.../dp/B0099AQNAI
Old 04-17-13, 09:59 PM
rj4510
rj4510's Avatar
both sides on mine were leaking and one was almost totally dry. I got the full resbuilt axles from Napa and had a trusted mechanic swap them out and had him throw on some better rotors and pads while he was at it. That was over two years ago and all has been well. The breaks have never been better with no warping.
8901alex
NX - 1st Gen (2015-2021)
10-20-14 05:15 AM
jbl-1985
08-25-14 01:04 PM
dcjeep
08-24-06 10:52 AM
Scotty99
01-29-06 05:52 PM
Davtown
09-17-04 11:10 PM
Quick Reply: front axle boots
