LED DRL and fog lamps
I want to replace the DRL/turn signal bulbs with switchback LED types in my 2006 GX. So I bought from jdmtoy. Has anyone here used these bulbs? Do these require a resistor across to prevent hyperflash or other issues? If yes, what resistor (spec) is used?
I also bought fog lamps from the same outfit. For some reason, the lamps test out ok when connected directly to the battery source, however do not work when put into the fog lamp assembly I tried both lamps, unsuccessfully. The halogen lamp works Any clue on what I could be doing wrong?
Thanks for any help.
I want to replace the DRL/turn signal bulbs with switchback LED types in my 2006 GX. So I bought these from jdmtoy. Has anyone here used these bulbs? Do these require a resistor across to prevent hyperflash or other issues? If yes, what resistor (spec) is used?
I also bought these fog lamps from the same outfit. For some reason, the lamps test out ok when connected directly to the battery source, however do not work when put into the fog lamp assembly I tried both lamps, unsuccessfully. The halogen lamp works Any clue on what I could be doing wrong?
How does the current bulb double up as a DRL/turn signal? Can someone help me with the circuit/wiring so I can figure out a workaround. I want to get away from the "yellow" look of the DRL but would want to keep the DRL. Is there some other solution.
Related to fog light - had to reverse the connection to make it work. However, the light is not bright enough. Is there a LED H3 bulb that matches the brightness of a 55W halogen?
Cheers.
You need this, which works fine as drl and turn light - but they need resistor or they will fast blink.
Im interested to know ur findings about the fog light.
Also, will keep you posted on what I do with the fogs....at present, I am considering either a 7.5W "plasma LED" or a HID bulb. Let's see.
Cheers.
XenonDepot
Club Lexus Vendor Marketplace
86
11-18-15 07:49 AM
