Dealership Suggests Full Engine Replacement
Very easy to a leak down test. Put cylinder top dead center. Use a 3/8 extension out in camber rotate crank until it is at the highest. Buy gauge from harbor freight. Put air in. Listen for the air. If it bubbles the radiator then it's head gasket. If u hear it inthe throttle body then it is intake valve. If it is dip stick then you know rings or pistons. If it is exhaust then you know exhaust valves. $60 gauge and a compressor. Probably burnt valve or sticky valve
Thanks for all the information, you guys are great. Do any of you have an idea what it would cost to have a valve job done on a GX as it really seems to look like that is the problem. Also I have a call into Lexus Corp and they said i should here back within 2 days, if they tell me they can't do anything I will have a leak down test done and let you guys know what i find out.
Thanks again
Thanks again
Former Sponsor
definitely get a second opinion at a reliable independent. You might try Angies List. It's only 3.99/month or something and you can get a real good idea about almost any local shop.
wow i dont believe this. i have a 09 gx470 and i had this same problem! but my check engine lights and vsc lights came on after my oil change. my mechanic told me that it was a evap code. but i was wondering how the evap system has any relations to the vsc lights. man i hope it isnt as bad as you guys how had the misfire in the cylinders
Maintenance Moderator
texas008
10-08-21 06:37 PM
cicio
GX - 2nd Gen (2010-2023)
11-03-17 01:08 PM
texas008
07-25-16 04:25 AM
letap4
09-07-09 08:14 PM
