GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Earlier 470s & front axle replacement?
Old 03-20-13, 07:28 PM
  #31
bauer26
bauer26's Avatar
Originally Posted by infinirx
Wondering if there is a decent digital repair manual I can buy out there. Would make this sooooo much easier.
Check your PM.
Old 03-20-13, 07:32 PM
  #32
infinirx
infinirx's Avatar
Originally Posted by bauer26
Check your PM.
Got it! Your awesome!
Old 07-16-13, 08:38 PM
  #33
tony400
tony400's Avatar
Default My gx470 CV boot
Bauer26,
Would you please send a copy of the manual? I will be replacing both front CV boots for my 06
Thanks in advance
Old 07-17-13, 08:45 AM
  #34
bauer26
bauer26's Avatar
Originally Posted by tony400
Bauer26,
Thanks in advance
Done, though I don't have specific instructions for a boot replacement just the whole axle.
Old 06-11-14, 12:39 PM
  #35
gfcipriani
gfcipriani's Avatar
Default I seek wisdom and knowledge
Check your PM.
me too! i would love to know how to do this as I am now faced with this issue. BTW, 04 GX470, 162K relatively hassle free miles. still running strong.
Old 06-11-14, 05:44 PM
  #36
MidniteGX
MidniteGX's Avatar
I used reman axles on my Toyota Previa 4trac. The job wasn't hard but the manual was an essential item. Any extra digital copies sent this way would also be much appreciated!
Old 06-12-14, 06:11 AM
  #37
ChiTownGX
ChiTownGX's Avatar
Originally Posted by 06isDriver
dont even pay them to do that. You can do it all yourself with a common food injector and some worm driven smooth side clamps. Like these: http://www.mcmaster.com/#catalog/119/283/=llapf6 430 Ss Smooth-band Worm-drive Hose Clamp, 1-1/4" To 2" Clamp Dia Range, 3/8" Band Width
then get you some cv grease from your local auto parts store and a food injector with a plastic needle. Unclamp the boots and pack the grease into the food injector. Slide that plastic needle underneath the boot lip and squeeze all that grease back in there. It may take 2-3 injectors worth. Reclamp with new hose clamps.
Enjoy a beer. You just saved yourself hundreds in labor cost...all for 15 minutes of work.
I just saw this older thread. I have leaking boots, but with no tears. so the re-grease, re-band is the way to go for me too. What does a food injector look like? And where do you buy one?
Thanks!
Old 06-12-14, 07:14 AM
  #38
ChiTownGX
ChiTownGX's Avatar
Thanks!
One more question. Is CV Grease anything special? Or can I just use the typical chasis lube for u-joints?
Thanks!
Old 06-12-14, 08:24 AM
  #39
chiph9
chiph9's Avatar
You're going to want to use the special CV joint grease. It's different.
Chip H.
Old 06-12-14, 08:27 AM
  #40
ChiTownGX
ChiTownGX's Avatar
Chip H.
Thanks Chip!! that's good to know.
Marty
Old 10-31-14, 09:10 AM
  #41
rlabair
rlabair's Avatar
Bauer26,
Could I get a copy of the manual mentioned in this thread? I've got to replace my 06 GX470 axles. Probably will go with the Cardones and repack and reboot my originals for back-up.
Thanks!
Old 12-20-14, 12:51 PM
  #42
ruhroh
ruhroh's Avatar
Bauer26,
Just noticed my inside boot is split on my 07 with 85k on the clock. I've done the axle shafts on a BMW X5 but would be interested to see if i can get a copy of the manual mentioned in this thread.
I used the Cardone brand on the X5 - bought at Amazon. Had good luck with it.
Thanks!
Old 04-30-15, 07:56 PM
  #43
Project470
Project470's Avatar
Default Axle part numbers needed
I have done quite a bit of searching here and Google trying to find part numbers for OEM FJ Cruiser front Axles to replace the ones on my GX. Does anyone happen to know the part numbers? Finding OEM parts online are usually about 25% cheaper than my local Toyota dealership. Any help would be much appreciated.
Old 12-30-18, 09:38 PM
  #44
dustyob
dustyob's Avatar
Ditto - also looking for said manual - particularly interested in the torques etc for doing the job right! Thanks!
Old 06-13-19, 04:31 PM
  #45
bludragoon
bludragoon's Avatar
To anyone replacing their front CV Axles on 2003-2009 GX470s or 4Runners, here is a great youtube video showing the process in great detail. I will be performing this service in a week or so as my inner CV boots have been torn for an undisclosed amount of time and are no doubt in need of R&R after 185,000 miles on them. I am using Cardone 665235HD replacement parts, $150 for a pair of them shipped. I may reboot the OG parts if they do not appear too worn or have too much play.
Video:
edon1455
06-26-21 08:06 PM
iRX400H
12-02-18 02:45 PM
PlotPoint
09-24-14 03:39 AM
64-04
10-03-12 05:09 PM
Quick Reply: Earlier 470s & front axle replacement?
