GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Can leaving the key in the ignition in the "lock" position make the battery die?
Old 04-04-12, 09:11 AM
vdeyfi
vdeyfi's Avatar
Default Can leaving the key in the ignition in the "lock" position make the battery die?
Hey everyone, first post. Just wondering if leaving the key in the ignition in the lock position causes the car to draw power from the battery.
Thanks
Old 04-04-12, 09:38 AM
RCsGX
RCsGX's Avatar
No...it shouldnt.
Old 04-04-12, 11:00 AM
vdeyfi
vdeyfi's Avatar
Cool, thanks. I had my GX battery replaced last month and this morning it wouldn't start so I had to get jumped. The only thing I could think that would have caused it was the fact that I left the key in the ignition but I'll have to do some more troubleshooting.
Thanks
Old 04-04-12, 11:05 AM
plunger
plunger's Avatar
It could be the reason.
You need to google parasitic draw and troubleshoot it. If you have a multimeter, you can find out if it is the reason.
Old 04-04-12, 08:43 PM
ALAN553
ALAN553's Avatar
Not the key, left key in ignition in garage overnight all the time
Old 04-15-12, 09:18 PM
rbx10
rbx10's Avatar
Its funny you post this. 3 weeks ago I was working on the GX and forgot the key in the ignition on lock position. The following morning I had to get a jump because my battery died.
-rbx10.
Old 04-17-12, 09:30 PM
Ancient
Ancient's Avatar
I leave my key in the ignition most of the time, since it is in my garage, no problem. However, I stared this post, just before last Christmas
https://www.clublexus.com/forums/gx-...-question.html
I have an 08, with the original battery and 66,000 miles. I had two occasions for no apparent reason where turning the ignition and click, click, click, no start.
When I did get a jump, started right up. Turned it immediately off and started without a jump. I have a testing device, which puts a load on the battery and it always read strong, that is why I didn't change the battery.
I went through the past winter (not as cold) running lots of accessories, no problem starting. I will change my battery this year because of age. I could never put my finger on what was reading a low voltage, or perceived low voltage and wouldn't let the starter ingauge.
To my knowledge, there is no relay on the GX, that prevents battery run down protection. I have on occasion, looked in my garage and seen the interior lights on, because one door was closed properly. I have left my visor mirror on, for who knows how longs. Car still started Life's little mysteries.
sjgIS350
01-20-14 10:33 PM
marty99
09-25-13 10:24 AM
BradTank
09-12-13 10:03 AM
anarchyx
07-26-12 07:13 PM
Jordo609
10-31-11 02:25 PM
Quick Reply: Can leaving the key in the ignition in the "lock" position make the battery die?
