Air Suspension Problems or Questions
#226
air bags
I had to replace the rear suspension air bags on my 04 last yr. It had about 100K on it..I drove around for awhile as sometimes it would pump up and ride fine..after awhile and when it started riding completely deflated and was a hard ride, I ordered a conversion kit and was going to put it in, in place of the original...
I didn't put the conversion kit in but took it to the dealer and had it repaired...while it was there I had the timing belt replaced...I think I paid $2300 for everything.
I still have the conversion kit sitting in the original box, never opened if someone wants to convert rather than pay the dealer. I paid about $450 with shipping..will take reasonable offers.
#227
I had problems with the suspension system (Rear & front) on my 2003 GX470. Its too much bumpy when riding off-road, however, I recently did suspension system overhaul; stabilizers butches, new shocks, control arms butches, when VSC warning lights came ON through out
#228
PROJECT COMPLETE!!! I replaced the rear suspension with Strutmaster conversion kit and I cannot believe the difference. first of all it rides great, has additional clearance and in my opinion is better than the original ride....I 've had my 03 since new and at 237K it runs like a charm. Next project is the front suspension, since that is all original.
BTW...Lexus quoted 4-5K to do this job...all in it cost me $537! Seriously if you have this issue and have over 150K on the truck go to coils...it will last longer than the replacement airbags and at that point who cares about resale, they'll screw you anyway on resale no matter what. No blinking dash lights and I also took the center console controls out and put in the small box to store my cell etc.
#229
Thanks, you have written pretty good information in your thread.
Heres the best way to figure out which component of the air suspension has died out.
With the car on, raise the height control to HIGH. Once it has reached this height, turn the car off and look at the height between the tire and the wheel fenders. Leave your car over night or a few hours and return to it. Has the measurement changed from when you had pumped it up? If so, you have a faulty airbag OR leaking air hose.
The best way to diagnose the issue above is to go get a spray bottle with soapy water. Spray down the airbags and the air suspension hoses. If you notice any soap bubbles starting to form, there is your leak!
Also while down under your vehicle, inspect the airbags. Do they have cracks in them? Does the plastic/rubber material look to be in good condition?
This is no good.
If the above did not yield you any luck, then proceed reading.
Go underneath your car with a 10mm wrench. To the side of both airbags, you will see this metal arm:
Using your 10MM wrench, go ahead and adjust both sides to the same setting, while adjusting the arms, raise and lower them with your hand and if possible, get some WD-40 and spray the living heck out of them. Then go into your GX and re-calibrate the air suspension (process shown below) and go for a drive.
On a side note, if you have ever turn your vehicle off and exited from the cabin only to hear what sounded like air coming out of the back suspension. That is completely normal, as long as it stops within 2-8 seconds. That is the rear air suspension removing the excess pressure it built up while on your drive &leveling itself.
Anytime you do any adjustment to the air suspension system it needs to be calibrated. Personally I do this about once a week, or anytime I feel the rear end isn't 100% in tune.
Start vehicle, and confirm the height control says the vehicle is in normal height.
Lower vehicle to low, and wait for the light to turn solid.
Raise vehicle to Normal height, and wait for the system light to turn solid.
Raise vehicle to HIGH height, and wait for the system light to turn solid.
Lower the vehicle to NORNAL, and wait for the light to turn solid.
DONE.
The system is not calibrated and knows its Low,Normal,High positions. It is recommended you do this on a flat surface, and while the vehicle is parked.
Any questions? Feel free to ask.
references:
Lexus Emp.
GX470 owner with one too many RAS problems.
This is no good.
DONE.
references:
Lexus Emp.
Hi Jafch1,
As you mentioned in your thread that air leaks for 2 to 8 secs, in my case it leaks for longer time. Ride is very bumpy seems like air ride is not working at all. Restarted again after few miles of bumpy ride, there was no leak heard. What could be the problem?
#230
It's normal for the pump to run for a few seconds after the people get out, as it readjusts to the new vehicle weight.
If it runs longer than 8-10 seconds then there may be a leak. Follow the procedure above with a soapy water sprayer to locate where the air is coming out. If you don't see any bubbles, consult your mechanic as it's likely something else.
Chip H.
Chip H.
#231
Thanks Chiph
Chip H.
Chip H.
#232
If the leak is on the edge of the airbag, the support could be occasionally blocking it, depending on how it settled once it parked.
Chip H.
Chip H.
#233
I am not seeing how an airbag can help with a nice ride, but perhaps I don't understand the concept.
#234
how old is the truck...those air bags have an end life...rubber inflating and deflating multilple times everyday, weather? i see you are michigan...salt...they crack and dry up....just like us...
#235
Thanks for your post. I am in a unique situation and ask for your experties. I am stationed overseas in the middle east with the government and I brought my 2007 GX470 with me. A couple of months ago the rear suspension air compressor started coming on more frequently. Really loud noise. Today I took it into a local mechanic shop and he thinks it is the shock absorber that needs to be replaced. I need to order any parts needed from the states. Thanks for any and all help...
#236
My truck literally just got converted to springs. I used FJ cruiser springs and in all honesty under normal driving it rides a bit rougher. It does, however, handle larger bumps much better and I no longer get the bottoming out feeling or hard jounce I did with the bags. My bags weren't leaking, my compressor went bad. It was throwing a compressor exhaust valve solenoid code for almost a year, so yes, there is an exhaust solenoid that regulates the amount of air in the bags. I actually prefer the "ever so slight" rougher ride, the truck seems more responsive.
#237
#238
What are the signs of air bag leaking?
I never hear the compressor run for no reason but it does seem that if I put the suspension to high once every 2 weeks and let it drop back to normal height, it seems to be more comfortable, but could be all in my head (found this info on another thread)
#239
#240
I am suspecting an air suspension problem similar to this as well. My height control works and my compressor does not seem to come on more than usual, but at normal height the rear seems to sit a little lower than it should... although the bump stops are never resting on the axle. I would say the gap is about 2". At normal height the measurement from the center of the wheel to the fender ranges from 20.5" -21". High mode = 22.25". Low = 19.5". Tires are 265/65/17. Since my height control works I don't suspect the sensors, and since the bumpstops never rest on the axle should I suspect a bags or hose leaking? I feel bottoming out over speed bumps and other similar bumps as well.
Other GXs I see seem to be a little higher in the rear. Any help would be great!
