tire size on 4runner rims
Old 02-13-12, 03:45 PM
Kaizer
Kaizer's Avatar
Default tire size on 4runner rims
I just bought a 03 gx470 and it needs some rims. I like the look of the 18" 08 4runner limited rims in hyper silver. What size tire should I get with those rims I would like something a little wider than stock. I have found the rims at Sparks toyota for a good price do I need to order the center caps and lug nuts also for it to look good. can I make the lexus center caps work. They require a vin # to get the part # for the rims and center caps and lug nuts is that normal.
Old 02-13-12, 05:00 PM
ROK
ROK's Avatar
I run 285/60 on 18x8 wheels which also feature a more aggressive offset with zero rubbing. I believe if you try to run these on the 7.5" 4R wheels that sit in-board, you'll rub so I'd stick to going with stock tire widths else get wheel adapters.
I'm not even sure if you can run 285s on 7.5" wheels?
Old 02-13-12, 06:13 PM
Kaizer
Kaizer's Avatar
I was thinking of running 175/65/18 will that fit a stock gx470 with the 18" 4runner rims
Old 02-13-12, 06:14 PM
Kaizer
Kaizer's Avatar
I ment to say 275/65/18
Old 02-13-12, 07:09 PM
Ancient
Ancient's Avatar
Start up the car, have someone turn it lock to lock, and see how close you are to rubbing with the stock 265's. You don't have much room to play.
jennypenny
04-10-14 07:54 PM
Skitso-3
Wheels, Tires & Brakes Forum
03-15-10 10:26 PM
olddog
GS - 1st Gen (1993-1997)
11-29-05 09:37 PM
1 SiC LS1
Wheels and Tires Classifieds
23
12-27-04 01:22 AM
Quick Reply: tire size on 4runner rims
