GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Replacing Mark Levinson 6X9 door speakers with 6.5" home audio speakers
Old 12-07-11, 06:11 PM
zakatak007
zakatak007's Avatar
Default Replacing Mark Levinson 6X9 door speakers with 6.5" home audio speakers
I have read a lot of threads regarding the sensitivity of the Mark Levinson system to using alternatives. I am against using any 6X9 speakers less than 8 ohms and I do NOT want to buy replacement ML 6X9's. What I've decided to do is get an adapter to place a 6.5" 8 ohm speaker into the 6X9 bracket.
My question: Aside from the ohms, what specs should I pay attention to when searching for my replacement 6.5" speaker. How many watts, etc.?? Also, is mid-range driver the way to go? Is there a difference between "mid-range" and "mid-bass"??
Thanks.
-Zach
2004 GX470
Old 12-09-11, 01:05 PM
headcrash
headcrash's Avatar
As odd as it sounds a 6.5 sounds and performs much better than a 6x9 ask around. But since you are installing a 6.5 I recommend just removing the entiere plastic housing and making your own out of MDF. I bough a piece of 3/4" MDF at home depot for around $10 (not full sheet) made 2 trim rings and works perfectly. I should note that there was a slight raised edge where the screw holes go so I used a dremel to sand it down so when it sits on the door it is flush, you will know what I mean when you put the board on the door as you will feel the gap.
In my setup I also ran new wiring which is the large gauge white wire, I wanted both sound and quality so the old stuff had to go Here are some picts to help
Attached Thumbnails Replacing Mark Levinson 6X9 door speakers with 6.5" home audio speakers-img_2031.jpg   Replacing Mark Levinson 6X9 door speakers with 6.5" home audio speakers-img_2032.jpg   Replacing Mark Levinson 6X9 door speakers with 6.5" home audio speakers-img_2033.jpg
Old 12-09-11, 02:51 PM
zakatak007
zakatak007's Avatar
HeadCrash, you're a baller for the pics and the info. Any particular reason you avoided just placing an adapter onto the OEM plastic housing? What brand/model 6.5" did you use there? How difficult was it running the wires? Thanks!
-Zach
keith5867
05-22-14 01:47 PM
JCam
16
12-04-13 01:29 PM
notkrap
08-18-13 06:59 AM
Xanadu350
07-06-13 02:25 PM
nmmuzykam
09-15-09 07:01 PM
Quick Reply: Replacing Mark Levinson 6X9 door speakers with 6.5" home audio speakers
