GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Where is the Bump Stop?
Old 12-08-11, 07:11 AM
mann777
mann777's Avatar
Chris...the Bump is right there in the snippet you have attached...here is the circled one.
Old 12-08-11, 07:59 AM
mann777
mann777's Avatar
Gents....There is three reason a GX for bottoming
1. Overloaded.
2. Pneumatic Cylinder Weak ( Solenoid Assy )
3 Shock Absorber ( worn out)
The Sensors when it does not read the values of the height, it cannot interpret the signals to the ECM ( here the Height control is not faulty)becoz the Accumalator solenoid Valve has malfunctioned & it cannot signal to the ECM. Now coming to the bottoming, there are two ways to look. The Compressor is flat there by not building pressure to raise the required height. . The Suspension fluids pressure is low and thereby no gas is present. How to check .Bleed the air , thereby you get the suspension adjusted manually to the range required. Because if the N2 gas if it is in the fluid , it will bellow thereby telling you that there is malfunction within the Stab control assy accumulator housing. Here the N2 gas enters the suspension fluid which causes the fluid pressure to decrease, and that is reason you get the bottoming out.
hope you have understood the long procedure involved.
Old 12-08-11, 01:32 PM
redrocks
redrocks's Avatar
1. Overloaded.
Thanks Mann777,
I think I can eliminate items #1 & 3. As always, thanks for sharing your wealth of knowledge,
Old 12-08-11, 07:11 PM
ROSCOGX470
ROSCOGX470's Avatar
Originally Posted by Ancient
ROSCOGX470 There is another thread, with a posting in the start of December. On page 3, there is a picture of the ride height sensors and how to adjust with basic tools. Hopefully, I copied this link correctly:
https://www.clublexus.com/forums/gx-...version-2.html
Thx, Ill take a look.
steveski
05-27-17 02:41 PM
SimplyZBes
General Classifieds
03-23-12 12:13 PM
snook
Wheels and Tires Classifieds
09-18-09 10:50 AM
snook
SC400 / 300 Classifieds
18
09-15-09 07:58 PM
Quick Reply: Where is the Bump Stop?
