GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Auto Door Unlock
Old 11-01-11, 04:37 AM
ncphoto
ncphoto's Avatar
Default Auto Door Unlock
I believe my GX470, 03 model, use to unlock the drivers door automatically when I removed the key from the ignition. Now that the battery has been replaced the doors no longer unlock when removing the key.
Is there a way to reprogram this?
Old 11-01-11, 06:21 AM
Drew903
Drew903's Avatar
Yes, you can reprogram that. Check out this link.
https://www.clublexus.com/forums/gx-...-function.html
Old 11-02-11, 04:24 AM
ncphoto
ncphoto's Avatar
Thank you Drew, got then to unlock when the vehicle is in park and the ignition key to the on position as the directions gave. But, do you know if there is a wat to:
(b) Unlocking linked with the shift position
All the door are unlocked automatically when the selector lever is moved to the "P" position with the switch in the "OFF" position only.
In other words if the vehicle is still running, I don't want them to unlock with the kids in the back.
Thanks
Old 11-02-11, 12:42 PM
ALAN553
ALAN553's Avatar
Front doors will,always open when you pull inside handle even if locked.
Albatross
SC- 1st Gen (1992-2000)
04-02-15 11:58 PM
Natey2
09-12-13 05:15 PM
kino1161OL
GS - 1st Gen (1993-1997)
19
11-07-08 02:12 PM
SmokeyGS
06-04-08 07:57 PM
rhwest2008
08-16-07 06:13 PM
Quick Reply: Auto Door Unlock
