GX heading to dealer for variety of issues (surging, speaker, mirrors)
Finally heading into a week without insane business travel (or spring break) so I thought I would get a few nagging issues with my truck addressed.
Posting so others can follow along with these issues, or make suggestions.
- First is a continued surging issue. Whether on flat land doing 65 with cruise or stopped at a stop light I have a repeated issue where the GX will pick-up the RPMs by a few hundred revs. Annoying on the freeway, unsafe in parking lots and pulling into my garage. They previously said they couldn’t ID the issue, but I am not taking the vehicle back this time until it is fixed. Was about to pull my hair out on a 200 mile drive yesterday.
- Second, I got in my truck after letting it sit in an unheated parking garage for about a week (was out of town on business) and it sounded like the speaker in my passenger rear door was blown. I have a feeling it probably is damaged, but only exhibits when cold (heard it a couple other times this winter).
- Finally, my mirrors are a total basket case. Only dip occasionally, don’t dip all the way, etc. Pretty standard issue on these trucks.
Happened to our last XC90 along with some other issues. Could be a be the alternator. We also eventually replaced the main computer. It sounds crazy but I would check the alternator. Autoparts store should check it for free.
Good luck
Good luck
its under warranty - it isn't getting picked up until the dealer fixes it. typical bs, they tell you up and down during the purchase process and i have these three issues and it hadn't had the driveline done, so that got replaced in january immediately after buying the truck.
also, in my experiance, when a/c kicks in that results in decelleration and sluggish performance. this represents a speed increase. opposite of what one comes to expect when a/c kicks in.
Do a cleansing on the Mass Air Flow Sensor , and have the throttle body Intake Air flow also cleaned. This is sensitive job, if you are pro, do it, or else take it some pro mechanic who you know could do this job with ease.Also check the PCV valve, maybe that is clogged, time to replace. I am sure this should resolve yr problem. cheers
morgt0
GX - 1st Gen (2004-2009)
33
06-09-04 08:16 PM
