GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Auto Tilt Reverse Side mirror issue
Old 01-05-11, 07:53 PM
rbx10
rbx10's Avatar
Default Auto Tilt Reverse Side mirror issue
Hey fellas.
I notice that whenever I put the GX in reverse, the driver side view mirror doesn't come down all the way like the passenger side view mirror.
The driver side view mirror only tilt down half way and its bothering me. I try to play with it but its still behaving the same way. I read somewhere on a different thread where the dealer had to replace the motor...Hope that is not the case with me.
Any thoughts guys ?
Thanks
GX470 '08
Navigation
6K White SMTLEDs (all 4 doors/License Plate)
Old 01-05-11, 09:29 PM
Johnny Rad
Johnny Rad's Avatar
Yup, "common" failure for the GX. I've got one on order from the stealership ... it's been so long now that I wonder if they didn't order it or I somehow missed their call. Oops, gotta get that figured out.
If I recall correctly, the service manager said it also happens a bunch on the GS.
Old 01-06-11, 07:08 AM
ALAN553
ALAN553's Avatar
ordered the actuator on line, about 150 bucks, took about 15 minutes to replace.
Old 01-06-11, 07:29 AM
FlzRider
FlzRider's Avatar
If you guys are under warranty, this should be replaced for free. There is a TSB about this issue.
Old 01-06-11, 07:52 AM
redrocks
redrocks's Avatar
rbx10,
It's an '08 and still under warranty covered under electrical/mechanical parts.
Old 01-06-11, 11:09 AM
malmon
malmon's Avatar
I had the same issue and the dealer replaced it under warranty.
Old 01-06-11, 07:30 PM
Johnny Rad
Johnny Rad's Avatar
One side or both?
Old 01-06-11, 09:32 PM
rbx10
rbx10's Avatar
Thank you all !!
Old 01-07-11, 06:05 AM
IXI187IXI
IXI187IXI's Avatar
ha this seems to be a common problem on all Lexus'. its a known problem with the crappy parts inside the mirror which dont allow it to tilt down anymore.
Old 10-18-11, 06:17 PM
SimSimGX
SimSimGX's Avatar
Lightbulb Cheap Fix
I just finished fixing both mirrors on my `08 GX. Total cost = $12 + 2 hours work.
I`m a pretty handy guy so if you`re not capable of handling a philips screwdriver and electronic connectors, please do not try this.
I bought a can of `Electronics Contact Cleaner` for $12 at my local electronic supplier. Took the whole thing apart with the aid of the TSIB provided by lexus (Attached PDF file). NOTE: You do not need to disconnect the battery during this procedure; however make sure your car is turned off the whole time you`re working on this.
I used the Contact Cleaner and sprayed every electronic component I found inside the Actuator, greased the plastic parts and put it back together.
My mirrors are now working perfectly fine
Good Luck!!
File Type: pdf
The following 3 users liked this post by SimSimGX:
kamlung (08-22-18), Listers (03-16-17), Ssd108 (11-24-17)
Old 10-19-11, 11:02 AM
meyer65
meyer65's Avatar
Mine also had the TSB performed under a previous owner.
Old 10-21-11, 11:32 AM
brycejaq
brycejaq's Avatar
Originally Posted by rbx10
Hey fellas.
Any thoughts guys ?
Thanks
GX470 '08
Navigation
I had an 06 GS (which has the auto-titling mirrors--I thought they were annoying & turned that function off, since I knew they would eventually break and I'd have to pay $$$ to get them fixed).
I never knew our GX had the auto-titling mirrors, though, literally until I read this post...guessing the previous owner of mine turned the function off, too. I never really saw the point in having the mirrors tilt down since both of mine had/have NAV & the back-up cams.
Old 05-05-13, 02:34 PM
fishhuntnc
fishhuntnc's Avatar
Thanks SimSimGX ! I also had the passenger side mirror issue. Took it apart following the TSB, sprayed some electronics cleaner on every part I could get to, re-lubed the moving parts with white grease, re-assembled, and now it works like new. Total cost = $0 since I already had the cleaner and grease. GX Forum rocks. Jeff
Old 05-08-13, 02:33 PM
oardila99
oardila99's Avatar
This happens to my GX as well. I now wonder if it is designed to tilt the driver's mirror. I'll try SimSimGX's fix when I have time.
OA
Old 06-30-13, 11:56 AM
MSGX470
MSGX470's Avatar
OA
If the Mirror adjustment switch is to the left both mirrors should tilt when in reverse.
If the Switch is in the right position only the passenger side should tilt.
If the switch is in the middle nothing should happen when in reverse.
The following 2 users liked this post by MSGX470:
Ssd108 (11-24-17), tomclayton (03-17-17)
Quick Reply: Auto Tilt Reverse Side mirror issue
