GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Here's How To change Front Right turn signal bulb (with photos) in your Lexus GX470
Old 01-04-12, 04:25 PM
  #31
ebradford
ebradford's Avatar
Originally Posted by GXM35
Does this advice hold true for both sides? I replaced mine from above on the non-battery side with little problem, but when I looked at the side with the battery, I saw there may be trouble changing it...
coming up from underneath works on both sides. you can come at it from the top, though i haven't figured out a way to wrench my wrist backwards with enough torque to twist to unlock it. i make this repair a lot for some reason, typically if i bounce down a back road too fast. these directions are spot-on.
Old 01-19-12, 12:17 PM
  #32
swaroopnsk
swaroopnsk's Avatar
It took me 10 mins ( double the time recommended because of my engineering degree ;-) 2007 GX470 also has the same assembly and mechanism for turn signal.
Thanks Jeff! You actually saved me a trip to the lexus dealership plus a $70 ( yeah! thats what they are charging now for changing the bulb!) You should consider authoring an illustrated Lexus owners hand book for dummies! I will be the first one to buy.
Old 01-20-12, 08:01 AM
  #33
GXM35
GXM35's Avatar
Default Confirm
This is the driver's side bulb or passenger side?
Old 01-20-12, 09:15 AM
  #34
BurgBoxstr
BurgBoxstr's Avatar
works for both sides...
good luck
Old 01-22-12, 07:45 AM
  #35
sprocket
sprocket's Avatar
Just did my driver's side. Took about 5 minutes (I'm not an engineer ).
Thanks to the OP for taking the time to post this.
Old 01-25-12, 10:54 AM
  #36
GXM35
GXM35's Avatar
Default Sweet
good luck
Thanks! Looks like it's a breeze.
Old 01-31-12, 05:04 AM
  #37
97JZA80
97JZA80's Avatar
Originally Posted by redrocks
I thought you might have installed switchback lights by V-LEDs, which change to amber when turn indicators are used.
http://www.v-leds.com/Exterior-LED/T...viewsTabAnchor
Whoa, these are badass..might have to pick them up...
Old 01-31-12, 05:46 AM
  #38
redrocks
redrocks's Avatar
Let us know how they work out.
Old 01-31-12, 11:21 AM
  #39
cdew002
cdew002's Avatar
I second that motion
Old 01-31-12, 07:06 PM
  #40
cdew002
cdew002's Avatar
If I'm reading the warning on these lights, they won't work with our vehicle since this bulb would be the same as the DRL - can someone else verify that I am reading that correctly?
Old 02-02-12, 04:42 AM
  #41
97JZA80
97JZA80's Avatar
I saw that same warning, might have to just email the company. Bigger issue is, am I seeing it right that there isnt an 1156 switchback?
Old 02-04-12, 07:26 AM
  #42
Trixtek
Trixtek's Avatar
Default Works on the 2008 GX470 too
It took longer to go to the auto supply to buy the bulb than it did to install it.
Thanks for the photos, that's a big help.
$5.49 at AutoZone for the same package of two bulbs shown. Still better than $75 at the dealership (that would be about a $70 'free' car wash!) lol
Old 06-15-12, 07:58 PM
  #43
RickC5
RickC5's Avatar
This is a good story...
Noticed no right front turn signal on the way home today. The "Lexus brick" (owners manual) was no help at all. Searched the site & found this thread. Laid down, reached up & removed the bulb according to the photos. Looked at the bulb carefully and it looked fine--you can usually see a blown filament. On a whim, I just replaced the bulb & voila! It works fine now. Had to be the simplest & quickest fix ever.
However, some spare bulbs are definitely in order.
Two pack of bulbs @ Autozone : $4.99.
Old 06-17-12, 03:14 PM
  #44
Matsui
Matsui's Avatar
Yes, this thread was very helpful.
It was a little intimidating looking up laying under the car, but didn't take more than 5 minutes.
Old 06-23-12, 10:15 PM
  #45
MSGX470
MSGX470's Avatar
Thumbs up
Nice photos and writeup.
Quick Reply: Here's How To change Front Right turn signal bulb (with photos) in your Lexus GX470
