GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Timing Belt or Chain
Old 03-18-10, 11:41 AM
I6turbo
I6turbo's Avatar
On the subject and FWIW, my neighbor's son has a '01 LX470 (same engine as GX, of course), and he just changed his timing belt for the first time at a little over 150K miles. The belt still looked good. It had a small section that was begining to show enough fatigue that would make you want to replace it.
Old 03-23-10, 07:30 PM
ROSCOGX470
ROSCOGX470's Avatar
The recommended 90k miles is just that a recommendation. My buddy has a 03 GX470 with 135k on it still has factory timing belt. It's one of those things-some people are lucky some not so much.
Old 03-26-10, 08:42 AM
mann777
mann777's Avatar
There is a Drive Chain which is within the Transmission which is covered under the Powertrain warranty. Hope that is not what you are asking.
Old 06-24-13, 12:48 PM
muldowney2
10th Gear
muldowney2's Avatar
On some cars, the failure (breaking) of the timing belt causes significant engine damage, such as the destruction of the valves as the pistons and the valves move out of sequence. Other engines are what is referred to as "freewheeling". Does anyone know if the 2007 GX-470 is freewheeling or not? Thanks.
Old 06-24-13, 01:14 PM
ALAN553
ALAN553's Avatar
I believe on Toyota a timing belt failure is not catastrophic, as opposed to when I had an Audi I was warned to have that belt done on time because the results would not be good if it failed.
Old 06-24-13, 01:43 PM
jnat306bg
jnat306bg's Avatar
From what I've read the 4.7 is an interference engine. I believe that the belt also controls the cam(s) which means the valve train would stop moving but the bottom end would continue with catastrophic consequences.
Please correct me if I'm wrong.
Old 06-24-13, 05:22 PM
Niteblu
Niteblu's Avatar
This is one area where the risk of not doing the full service (timing belt, water pump, and seals) at 90k, is not worth the reward. Although it is not cheap, the dealer documentation on a benchmark service like this one has value in peace of mind and resale. IMHO
Unless you have complete confidence in you doing the job, don't attempt the job.
Old 06-27-13, 03:56 PM
KLF
KLF's Avatar
Originally Posted by ALAN553
I believe on Toyota a timing belt failure is not catastrophic...
This used to be the case, but not with the 1UZ/2UZ V8. It is an interference engine, as are all the V6 engines with VVT-i. Going much more than 90K on a timing belt is a severe gamble.
Old 06-27-13, 04:43 PM
ALAN553
ALAN553's Avatar
I stand corrected
Lexus
2.5L Non-Interference
3.0L V6 Non-Interference
3.3L V6 Non-Interference
3.0L Inline 6 (1992-97) Non-Interference
3.0L Inline 6 VVT-i (1998-2006) Interference
4.0L Interference
4.3L Interference
4.7L Interference
rennwerkes
07-29-11 01:53 PM
SCLover777
Performance & Maintenance
02-02-09 07:57 PM
swat1727
12-11-08 12:44 PM
MarkMacGS4
Maintenance
08-08-02 11:40 AM
Quick Reply: Timing Belt or Chain
