GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Just replace differential and transfer case oil
Old 11-23-09, 01:55 PM
  #31
EyeKutr
EyeKutr's Avatar
So the 2 differentials and transfer case can be replaced with mobil 1 75-90 .....can someone please tell me how much is needed for all 3 so I can pick some up for my mechanic to change for me. thanks
Old 11-23-09, 02:07 PM
  #32
jditom
jditom's Avatar
I can't recall but it is the spec section of your manual.
Around 6L for all 3.
Old 11-23-09, 02:30 PM
  #33
EyeKutr
EyeKutr's Avatar
Thanks JD
I am pretty sure the differentials are pretty easy...remove drain plug clean and let it drain then remove fill plug and fill until it is level with the bottom of the fill plug....is the transfer case similar....I dont even know what or where that is LOL
Old 11-23-09, 04:16 PM
  #34
jditom
jditom's Avatar
Always remove the fill plug first.
Then remove drain plug, clean and refill until fluid flows out of the fill hole.
T-case is the same but they use allen bolts.
Old 09-04-14, 04:05 PM
  #35
shinbo
shinbo's Avatar
Any other recommendations besides Mobil 1 75-90?
Old 09-05-14, 06:20 AM
  #36
chiph9
chiph9's Avatar
I've used Castrol 90-weight with good results.
Chip H.
Old 09-05-14, 08:37 AM
  #37
ALAN553
ALAN553's Avatar
amsoil, severe gear
Old 09-05-14, 09:27 AM
  #38
470SNC
470SNC's Avatar
I second Amsoil severe gear, good stuff
Old 09-05-14, 10:49 AM
  #39
burny
burny's Avatar
Give this a read
http://www.google.com/url?url=http:/...srHHVZZ0cUAobg
Acrad
GX - 2nd Gen (2010-2023)
356
12-26-23 04:36 PM
Davenlei
08-14-14 04:20 PM
malrafe3i
07-19-13 04:36 PM
JASP615
03-08-10 07:08 AM
nyc11370
21
04-10-05 07:58 AM
Quick Reply: Just replace differential and transfer case oil
