GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Side Step Lights
Old 11-30-15, 02:01 PM
NTH
NTH's Avatar
^ IIRC, 168 and 194 bulbs are interchangeable. 168 are brighter than 194.
Old 11-30-15, 02:42 PM
BlackCat81
BlackCat81's Avatar
Originally Posted by Booyah
Those LED's you bought, where else in the GX did you install them besides the running boards?? Also dont we use alot of 194 bulbs, these bulbs do not cross reference to 194?
The 194's are everywhere. Door panel, running boards, license plate lights, front running lights, etc.
Old 11-30-15, 02:55 PM
maxx430
maxx430's Avatar
just not the dome light inside the car. I think they are 31mm festoon except for the very front, they are something different. I think the front are ba9s.
Old 11-30-15, 09:39 PM
mswtoyota
mswtoyota's Avatar
I put the leds in the license plate lamps as well (kind of a PITA to remove the entire rear door panel to get to 'em). I also did 2 panels for the center dome (not a 194-different type), and ordered 1 more for the rear. The front two are going to be a little more tricky...
Here are the ones I used for the non-rear DVD, but WITH rear audio dome:
Amazon.com: Cutequeen Trading 2PCS White 5050 48SMD 48-SMD LED Panel Dome Light Lamp + T10 BA9S Festoon Adapter (pack of 2): Automotive Amazon.com: Cutequeen Trading 2PCS White 5050 48SMD 48-SMD LED Panel Dome Light Lamp + T10 BA9S Festoon Adapter (pack of 2): Automotive
Attached Thumbnails Side Step Lights-win_20151130_233240.jpg   Side Step Lights-win_20151130_233303.jpg
Old 11-30-15, 10:11 PM
GXallday
GXallday's Avatar
I'm sorry you removed the rear door panel, but that was not necessary. The clear lens that covers the bulb is removable from outside. That's how I did it. Should've searched the forum. Only the back up lights require removal of back door panel.
Old 12-01-15, 04:03 AM
BlackCat81
BlackCat81's Avatar
Exactly. They are 31mm festoon bulbs if I remember right.
Old 12-02-15, 09:22 AM
GadgetRick
GadgetRick's Avatar
I'll have to get on my back and check back there. Thanks!
Old 12-03-15, 08:53 AM
NR04
NR04's Avatar
When I used to have my running boards, I replaced the lights with Philips LED. I think I ordered them through HomeDepot online. Very white (no blue) and bright. Also replaced the license plate light with Philips LED.
The interior lights were all replaced with LED but I bought them from SUPERBRIGHTLEDS because Philips didn't make the right ones.
I had mixed luck with getting LED lights from Amazon.... some were too blue and some didn't last very long.
Old 01-18-17, 12:20 PM
levinsoy
levinsoy's Avatar
I just did the same with some 194 LED's I bought on eBay and what a difference from the OEM lights. It really does update the look and makes my first generation GX not look so old!
lexusboy18
10-29-08 12:39 PM
bighenet
04-23-06 06:58 PM
rfm001
Lighting
12-22-04 08:34 AM
Suprast4R
SC- 1st Gen (1992-2000)
05-22-04 12:07 AM
Quick Reply: Side Step Lights
