GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Built-in Navi override so you can enter address while driving
Old 02-27-08, 01:11 AM
RyanofCA
RyanofCA's Avatar
Default Built-in Navi override so you can enter address while driving
I found these steps and have verified they worked for my 2006 Lexus GX 470.
This will allow the passenger (as we all know the driver shouldn't be doing it) to enter the address while the SUV is moving.
I only have one Lexus so I don't know if the same steps will work for other Lexus models. Hope they worked for yours.
With the Navi on
tap Menu
tap Volume
tap upper left of the display once
tap lower left of the display once
a menu of options should appear, press and hold the Override option until you hear a beep then let go
hit the address button and you should be able to enter the address while driving
This only works until you turn off the Navi so next time you're on the road you must do it again...only takes seconds to do and works great!
Enjoy and drive safely.
Old 02-27-08, 05:34 AM
The G Man
The G Man's Avatar
It wouldnt work for the 08 GX with gen 5 nav, Lexus has taken out that tech bypass.
Old 03-04-08, 08:05 PM
Roger108
Registered User
Roger108's Avatar
Tried it on my 04 but doesnt work, my mech at lexus said he just needs to cut a wire.
Old 03-04-08, 08:10 PM
cmarshack
cmarshack's Avatar
Cutting a wire is permanent, but if you don't mind go for it!
If you want to do the override the 04 is a little different:
With ignition key on.....
Press on "I agree"
Press on "Menu"
Press on "DVD"
Press on upper left corner of screen
Press on lower left corner of screen
Press on lower right corner of screen
Press on "Override" and hold until a beep is heard
Press "Back"
Press "MAP / Voice"
That's it!
(credit CAPARITO for this one)
______________
Old 03-05-08, 10:16 AM
kyeung33
kyeung33's Avatar
I tried both instruction on my 07 GX470 but they don't work. Does anyone know the correct instruction? Thanks.
Old 03-05-08, 11:09 AM
JGX
JGX's Avatar
Default nav overide
I tried both of these on my 2003 and neither works. Any idea which wire needs to be cut?
Old 03-05-08, 11:22 AM
Roger108
Registered User
Roger108's Avatar
Press on "I agree"
Press on "Menu"
Press on "DVD"
Press "Back"
Press "MAP / Voice"
That's it!
______________
WOW! thanks man... I havent had this much joy, since 4 yrs ago when someone discovered the display double tap, where you can see the reverse cam while you drive ( i never used it but it was fun!!!!)
Old 03-05-08, 02:10 PM
gsobol
gsobol's Avatar
Can you elaborate???
Old 03-05-08, 02:20 PM
super_cjc
super_cjc's Avatar
It does work on my 04GX.
Old 03-05-08, 02:51 PM
lonewolf69
lonewolf69's Avatar
... when someone discovered the display double tap, where you can see the reverse cam while you drive ( i never used it but it was fun!!!!)
Roger,
You simply cannot drop a bombshell like this and NOT explain it...??!?? Please share the wealth!
Thanks in advance!
-Alex
Old 03-05-08, 08:48 PM
Roger108
Registered User
Roger108's Avatar
haha sorry about that... well back in the day on club lexus forum... when no one knew what the clunk in the drive shaft was.... before there was even a tsb... all the way back when having HID's on you GX was the hottest mod around! This awesome GX owner discovered this diagnostic check on his gx and posted it for all of us here are the directions:
I know for fact that this works on the '04 GX
1)turn you ignition on
2) I agree
3) hit display( the square box)
4) tap the top left and bottom left of the outlined box twice(NOTE: must be tapped together.
Just took some pics for you guys here is what its going to look like when you get to the screen:
and
to get back to the your nav.. click and hold display botton until screen resets(3 secs normally)
Old 03-05-08, 09:53 PM
lonewolf69
lonewolf69's Avatar
Thx Roger, I "resemble" those HID = HOT MOD days in the Feb-March 2005 when I ordered and took delivery of the 2005 GX... Now, I seem to recall this feature was available also on the 2005 via the Gen 5 service menu also!
I'll have to check it out tomorrow!
-Alex
Old 03-06-08, 08:52 PM
Roger108
Registered User
Roger108's Avatar
With the Navi on
tap Menu
tap Volume
Major Problem:
I was messing around with the versions menu, and i clicked a new version to see what it was... the screen went to Error, invalid disc. Unable to read version. So i get radio, and climate but no nav..
I tried to reset the comp by:
1) I unpluged the batt for 5 mins (failed to help)
2) Ejected the disc and changed it.(failed)
So im stuck with this caution screen.
any suggestions b4 i take it to my lex tech?
Old 03-06-08, 11:33 PM
Capirato
Capirato's Avatar
Major Problem:
Any suggestions b4 I take it to my lex tech?
Try removing the DVD and re-inserting it.
~ Cap
Old 03-07-08, 11:17 AM
Roger108
Registered User
Roger108's Avatar
thanks.. but that was the second thing i tried... it reads the disc and then the error message comes up.. part of which is in japanese
Quick Reply: Built-in Navi override so you can enter address while driving
