GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
How to change the oil on your GX470
Old 04-16-14, 03:22 PM
  #31
burny
burny's Avatar
No, that snap- on filter you pictured will work. Those bastards I bought my rig from put a cheap carquest filter on there and tightened it as tight as I have ever seen. I used that tool to bust it a loose
Old 04-16-14, 07:55 PM
  #32
MichaelD86
MichaelD86's Avatar
how do you reset the oil reminder?
Old 04-16-14, 09:32 PM
  #33
RCsGX
RCsGX's Avatar
Reset the light by following the procedure below:
1. Turn the ignition key to the “ACC” or “LOCK” position with
the odometer reading shown. (For details, see “Odometer and
trip meter” on page 61.)
2. Turn the ignition key to the “ON” position while holding down
the trip meter reset ****.
Hold down the **** until the light goes off. Before the light
goes off, it illuminates for 3 seconds, flashes for 2 seconds and
illuminates for 1 second.
** If the system fails to reset, the light will remain flashing. In this
case, return to step 1 and try again.
Old 04-17-14, 06:57 AM
  #34
IanB2
IanB2's Avatar
Is this for non-nav trucks or something? My maintenance reminder stuff is all in the nav system, no dash lights.
Old 04-17-14, 07:15 AM
  #35
MidniteGX
MidniteGX's Avatar
Yes it is. For nav owners, it's as simple as punching in the dates/mileage in the oil change service category.
Old 04-17-14, 11:18 AM
  #36
RCsGX
RCsGX's Avatar
I've always reset the light with the steps I posted from the owners manual. All I do in the navigation system is set what mileage I want the maintenance light to come on. Even if you have the navigation system you will still get the maintenance light on your gauge cluster though.....
Old 04-18-14, 08:22 PM
  #37
IanB2
IanB2's Avatar
Hmmm, the only maintenance/service lights I've ever seen on ours is on the nav screen, never anything on the gauge cluster.
Old 04-18-14, 09:25 PM
  #38
RCsGX
RCsGX's Avatar
Maybe that started '05+, I'm not really sure?
I know 100% the maintenance light "MAINT REQD" lights up in the gauge cluster though because it'll flash when it's getting close to change the oil and stay light when it's at and or over the mileage I set in the Navi menu.
EDIT: I just stumbled upon MichaelD86's thread asking what does the light mean:
https://www.clublexus.com/forums/gx-...eqd-light.html
He has an '04 w/ Navi so maybe your light is burned out in your gauge cluster....
I recently bought a 2004 gx and am not sure what year the gps disk is.
Also noticed there's 3 bumped maintenance light threads on page 1?
Old 11-11-14, 05:00 PM
  #39
Wronglane
Wronglane's Avatar
Hey guys,been changing the oil and filter for a while now without taking the skid plate off,using an oil filter wrench like the one in post #1. Its a bit of a pain,but,doable. A cap filter wrench with a long 3/8" extension would make it a snap. So I ordered one from Amazon(74 mm and 14 flutes) ,but,its the wrong size for the filter which is Toyota #90915YZZD3.
Does anyone know correct cap filter wrench for Toyota #90915YZZD3?
Its 14 flutes but I need the mm size.Thanks in advance.
Old 11-11-14, 05:41 PM
  #40
burny
burny's Avatar
73MM
I have this one and works for the GS300 and GX470
Amazon.com: Assenmacher Specialty Tools TOY 730 73mm Oil Filter Wrench for Toyota: Automotive Amazon.com: Assenmacher Specialty Tools TOY 730 73mm Oil Filter Wrench for Toyota: Automotive
Old 11-11-14, 06:39 PM
  #41
ALAN553
ALAN553's Avatar
Where does the oil drain to if you don't drop that front plate down? I have always been able to loosen filter with just hands and rubber gloves, never over tighten filter.
Old 11-11-14, 08:25 PM
  #42
Wronglane
Wronglane's Avatar
Originally Posted by burny
Thank you burny!!
Old 11-11-14, 08:30 PM
  #43
Wronglane
Wronglane's Avatar
I stuff a rag under the filter.I loosen the filter and take it out from the top of the truck hardly spilling any.If I do,I spray the plate with brake kleen.
Old 11-24-14, 08:26 AM
  #44
coloboardi
coloboardi's Avatar
I changed the oil in my GX for the first time this weekend. The write up from shodog was very helpful for first time changes. Removing the skid plate was easy. Whoever did oil changes on my gx before I bought it never re-installed the drain plug removable panel. My oil filter was screwed on so hard from the dealer that it broke my oil filter tool and started to crush the filter itself. Just a tip if anyone runs into this issue, remove one of the screws on the funnel plate and just rotate that out of the way. Once you do that, you will have A LOT more room to work with unscrewing the filter.
gmoneygo (05-25-19)
Old 08-29-15, 06:03 PM
  #45
SC3coupe
SC3coupe's Avatar
Does the skid plate has to be removed completely like this one to change the oil filter?
Quick Reply: How to change the oil on your GX470
