Tread Depth
Originally Posted by Capirato
I have Michelin Cross Terrains on my GX. What is the tread depth when new ??
~ Cap
~ Cap
Originally Posted by malhokc
A simple way is to insert a penny between the groove. If you see the top of the head, you need new tires.
If I was to wear down the tires to where the Penny's head would show, which BTW is 3/32nds, I should get a total of about 72,000 miles off of the tires.
Chances are however, that I will get new wheels and tires way before I reach 70,000 miles. I'm looking at the 18" wheels and tires the new 4Runner has.
~ Cap
My GX has 40,000 miles on the odometer. The tire tread's depth averages between 7 and 8 32nds on all four Michelin Cross Terrains. If I subtract 7 from 12, that shows that I have used 5 32nds of tread, therefore I've been getting 8,000 miles per 1/32nd.
If I was to wear down the tires to where the Penny's head would show, which BTW is 3/32nds, I should get a total of about 70,000 miles off of the tires.
~ Cap
~ Cap
As a general rule, tires are not safe and should be replaced when the tread is worn down to 1/16 of an inch.
~ Cap
pagemaster
GX - 1st Gen (2004-2009)
11-11-08 10:16 AM
