GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Clunk Fix with new TSB
Old 03-19-15, 04:48 PM
  #811
ALAN553
ALAN553's Avatar
Originally Posted by chiph9
The 4Runner guys are saying 2 squirts to the zerks on the U-joints, and 4+ to the one on the spline.
Chip H.
Ha, I go for 5 in the spline. On the u joints, can't over lube...extra comes out.
Old 03-22-15, 08:59 AM
  #812
GadgetRick
GadgetRick's Avatar
So I've done more investigating. Seems the TSB is, "obsolete," as the dealership guy said. Was for 7 years/70k miles. I'm way past both. So looks like I'm on my own.
Going to try greasing it up really well. My guy--who worked as a Toyota tech for many years before opening his own business--wants to try replacing the U-joints if greasing doesn't work. He's skeptical on whether the FCABs are actually the problem--as am I. I had a BMW 3 series. They were notorious for FCABs going bad. I know the feeling, this isn't the same feeling.
Anyway, if all else fails, I guess it's replacing the driveshaft. Anyone got a cross-reference part number for a less expensive version? Lexus want's $600 for theirs.
Thanks.
Old 04-03-15, 10:28 AM
  #813
jdeguzman1
jdeguzman1's Avatar
So I tried to make an appointment at my local dealer yesterday and was told that this TSB was done after the 4yr/50k miles bumper to bumper warranty. Not sure what to do next. Maybe try a different dealer.
Old 04-18-15, 01:58 AM
  #814
whit3b0y
whit3b0y's Avatar
New to the GX, is there pics or a simple Writeup on where\howto do this?
Old 04-23-15, 01:52 PM
  #815
bhesse
bhesse's Avatar
Mann this is the part # 37110-60A40 correct, I believe it has changed from 37110-60A4A, but Lexus said that is the correct shaft for the fix for my 05 GX
Just want to confirm before I buy today
UPDATE
Correct part # and if you order from;
http://www.mylparts.com
enter CL5 for discount
272.10 total :-) shipped and received in 4 days
Old 04-23-15, 02:48 PM
  #816
GadgetRick
GadgetRick's Avatar
Don't know what the part number is.
Had mine replaced over the weekend. Have been driving it since Monday evening and not one clunk yet. Me thinks it solved my problem.
Old 04-25-15, 08:47 AM
  #817
reddirt
reddirt's Avatar
I followed the lube instructions and the clunk is gone.
Old 08-04-15, 09:15 AM
  #818
RBW
RBW's Avatar
Default Clunk/Thump
I took my 2005 470 to the dealer today and was told I needed to pay nearly $1,500 and they would not guarantee that the new driveshaft would stop the clunk at intersections.
Does anyone know if any type of class action has been filed over this obvious product defect?
Thanks,
Robert
Old 08-04-15, 02:14 PM
  #819
Ali SC3
Ali SC3's Avatar
I heard even the new one can make clunks after time so might as well keep re-lubing the original, anyone experience that yet? maybe the new one doesn't clunk cause its filled it up with grease but that can't last forever also can it
Old 08-04-15, 03:59 PM
  #820
Max707
Max707's Avatar
Thanks,
Robert
Just have it greased every 5k miles and retorqued every 10k. The thunk will never cause a problem.
Old 09-25-15, 09:23 PM
  #821
schum4
schum4's Avatar
Which bolts need to be retorqued? I've had some success with greasing the u-joints and shaft but it always comes back.
Old 09-26-15, 02:10 AM
  #822
Max707
Max707's Avatar
Driveshaft, it's in the owners manual as a maintainace item. Just remind the dealer when you have your oil changed that you need the zerts on the drivetrain greased and the drive shaft retorqued.
Old 10-08-15, 09:22 AM
  #823
RBW
RBW's Avatar
Default Clunk in rear end of 470
I wish it were as simple as greasing the inserts. That does not work in my vehicle.
Alderson Lexus was of no help and wanted to charge me $1,500 without even any
indication that replacing the drive shaft would solve the problem. My guess is that
the problem is related to the suspension system but I cannot find anyone willing
to fix those annoying bumps that are becoming more numerous.
Robert
Old 10-12-15, 10:19 AM
  #824
spport
spport's Avatar
Default Clunk fixes
Robert
Information I have read on this site would agree with you that pumping some grease in does not address the problem. The TSB is posted in this thread. Said it feels like a bump from behind at or after stopping. Mine sounded like a clunk coming from the transmission shift area just after stopping and I could feel the truck bump forward.
1) Somewhere in this site there are pictures of a guy taking his propellar shaft off and greasing inside. Looks easy to do and addresses the problem. It has to be repeated in the future.
2) There is a TSB posted in this thread with the instructions for installing the new propeller shaft part #37110-60A40. It is redesigned not just greased up.
I have 89,000 miles on my GX470 and the propeller shaft was replaced at 72,000. It was an immediate fix. Extended Carmax warranty covered it with no charge in 2014. Without the warranty I would have put it in myself to save some money. Hope that helps.
Old 10-13-15, 09:19 AM
  #825
ScatAdams
ScatAdams's Avatar
Want to fix your clunk? Lift the damn thing. Clunk gone immediately...
Quick Reply: Clunk Fix with new TSB
