Cost to Repair Pulsing Brakes?
If out of warantee, what is the approximate cost to correct worped brake rotors in the front? What about expense if 4 way brake rotors correction is needed? Thanks all.
Sypderman
Sypderman
For the front disk rotor you are looking about 75-90 per disk and for the rear they will be probably a bit cheaper around 60-80 each. The rear disk rarely warp so I would change the front first and see if the pulsing goes away.
Another alternative would be, if the rotor still have some good meat left, you can get the rotors turned which will be around $15-20 per rotor. If you are going to change the rotors I would say the labor will not take more than 1hr for 4 disk. Good luck please keep us posted!
Regards,
Charleston
06 LX470
03 GX470 (gone)
02 Odyssey EXL (gone)
04 Scion Xa
99 Civic EX
90 CRX Si
Regards,
Charleston
06 LX470
03 GX470 (gone)
04 Scion Xa
99 Civic EX
90 CRX Si
