2005 Black GX w/ Sport Package Pics.
4everlexus,
That is the factor towing option. To be honest with you, I don't even know how it works . Never used a hitch before in my life. I guess I find out when I decide to tow something.
Tow Hitch: Aftermarket or not?
Originally Posted by soonerdude
4everlexus,
I am still looking into the tow hitch thing and for some reason, and please don't take offense, but your install appears to be aftermarket versus OEM? Take a look below...yours vs Lexus website. Then again, maybe the pic I am posting is not the 6,500lb capacity I have read about. I wish someone would weigh in on this?
Originally Posted by 4everlexus
Hi there Soonerdude...
You can tell by the decal on the hitch that it is not OEM. On mine it had a U-Haul decal, but the hitch was made by Curt.
~ Cap
Originally Posted by Capirato
I agree.....
~ Cap
~ Cap
Originally Posted by SacKen
The GX auto-lowers to the lowest setting when you get out. You can hear the air releasing near the rear.
Besides offroading, I have also used the height adjustment to connect and disconnect from my boat. Back up, lower the rear then put back to normal after the ball is under the boat. Reverse to disconnect from the boat. Reduces all the hand-cranking... yes I'm lazy
BTW, my GX (2005) does NOT auto-lower to the lowest setting when turned off. I just measured it after sitting 14+ hours off. Still at the N height. Measured at the back bumber in the middle.
You can't read the letters on the pictures (low res image). I'll post a better picture, but it is definitely Lexus OEM hitch. The rubber decal cover said Lexus. If you dont believe me, just go check it out at the dealer. Dude, if you don't like it. Don't buy it. IMO it looks more rugged than without the hitch.
What does the sticker say ??
~ Cap
~ Cap
Capacity When Used as a Weight Carrying Hitch
6500lb Gross Weight
650lb Max Tongue Weight
Please Consult Your Owners Manual for Proper Towing Techniques, etc.
I'm 100% postive it is a Lexus Hitch - and I agree and think the vehicle looks more rugged as well with it.
6500 lb Lexus Hitch
Originally Posted by MarcP
Something to the effect of:
6500lb Gross Weight
Lexus Hitches thar are mounted in the center in the Notch are rated for 5000 lbs.
~ Cap
Originally Posted by Bronsteen
Does this car have the dark interior. My deal in NJ says only the tan is available with the sport model. Thanks
Bill
Bill
My personal opinion (as all opinions are!) is that the Black Maple and all Gray interior is too much, too dark, too drab.
