2005 GX470's - Are you experiencing any vibration issues?
#31
I had the clunk...
on my 2003. Started to become more apparent when I got to 20,000 miles.
Not sure we are talking about the same thing, but while stopped, you would feel
the drivetain jump, sometimes it might feel like you got bumped from behind,
but mostly it felt like you had just gone from park to gear.
At first it was just every now and then, but later it seemed to be every time
you stopped.
Finally called my service adviser and he knew right away what it was and
how to fix it. They swapped the driveshaft in a few hours, and so far so good.
you stopped.
#32
Thanks for the list wogey!
From the list I have experienced the thunk, inaccurate temp. display, and the loose driver's seat. The thunk is very intermittent and something Land Rover owners would call "character". I think the height control electronics gets confused at stoplights I am a car fanatic, but didn't think it worth the effort ,and having the truck out of commission, to resolve it. The seat was fixed and the my dealer still has their collective head up their bum regarding the temp guage (e.g., SA, "how do you know its inaccurate?", my reply "because my Suby's temp guage says 78 degrees, the GX's says 54 degrees, and I'm wearing shorts and sandals.").
Martin
Martin
#33
Martin
Martin
#34
Originally Posted by gs400jon
Well, the temperature gauge is more accurate now but the mileage still reads 2 MPG high.
#35
Originally Posted by et415
Is that the average or the instantaneous MPG? How can you tell it's exactly 2mpg high?
#37
Originally Posted by rjfiore1
Just wondering what you get for mixed mileage? I think I get around 15 according to fill-ups and my math...
#38
I've had 2.5 gas fill-ups so far with my new GX. Fill up 1: 11.4 mpg (almost exclusively city driving); Fill up 2: (no data--was traveling out of town); Fill up 2.5: 14.3 mpg (mixed driving). I've been gentle on the gas pedal during my initial 1000 mile break-in, so I'm surprised my mileage hasn't been better.
#39
#40
I agree. You definitely need to break in your engine. You may not really determine the mileage for maybe 5-10k miles or so? I have 4500 miles on mine and get appx 15 w/ mixed driving. I do hope it gets a bit better! Maybe not though.
#41
I don't seem to have the "clunk" problem, yet. But I am sensing some vibration on the steering wheel around 60 mph. Any ideas/fixes besides the tire rebalancing? I got Michellins on mine. Also let me know if you think "some" vibration is normal. I'll live with it if it is indeed "normal."
#42
#43
If it bothers you, its a problem, let lexus know, let them fix it.
#44
Tires were cause of my vibration issue
I have Michelin Cross Terrains on my GX. I had the vibration issue between 60-70 mph. They tried balancing the tires while they were still on the vehicle - this got rid of some of the problem but not all. My service tech then rembered an issue where they sold a GX that had flat spots on the tires due to hot weather and sitting on the lot. They increased my tire pressure to 38 psi and told me drive it like that for about 200 miles. I noticed the issue went away at once and it has never returned. Hope this helps someone!!
#45
Originally Posted by metropol
First, I don't consider 'vibration' to be normal. I also felt vibration at around 60MPH, -- it usually felt 1900-2100 RPM. It was fairly brief ( I don't keep that speed for too long) but definitely there. I had cheap DUELER (sp?!) - I think Bridgestones, but I doubt it was the tires, more like a harmonic in drivetrain. It didn't bother me as much as the 'thump', AC not working when hot or climate control not keeping proper temperature..
