Neat little things you may not have known about your GX
All
I was wondering if maybe we could add some of the cool things that are in our GX that may not be that apparent to the general population, except of course to the car finatics! I have found...
That you can auto start your GX by turning and quickly releasing the key...
The sunroof air deflector automatically adjusts to cut down wind noise around 50 mph...
the truck beeps at you when you do something stupid and it tries to correct...
The side view mirrors tilt downward in REVERSE so you can see the curb while backing into a parking space.
There's the double set of sun visors, so one can be used on the driver's/passenger's side window and the second one can be used for the windshield.
If you haven't already done so, check out the Lexus all weather mats. I keep mine in the truck all the time. They are really heavy duty and look great.
Originally Posted by rjfiore1
All
Hmmm, when you said "general population", I assumed non GX owners who participate in the this forum. The GX owners know EVERYTHING about their truck, well, almost everything
Found out a new one today. I always knew the kids could watch and listen to a DVD with the headphones while I listed to the radio or CD player.
Today, my son figured out he could listen and control his CD through the rear screen using the and wireless headphones while I listened to FM. I thought he could only do movies. Too cool.
OK. This is weird. I got this from a guy who works for Lexus.
If you try to open the 2 (slow opening) containers on the center console at the exact same time, they take almost exactly the same time to open. The front windows and the rear windows are synchronized as well, within a few milliseconds. It's apparently a Lexus thing.
Originally Posted by Rx900
yeah, that is possible. What would be cool is if the front has a different radio station than the rear, and the front can listen to a different cd than the rear, and so on. Maybe that's the next technology in the next GX.
radio station is not doable.. but cd is doable.. just drop an audio cd in the rear dvd player and then they can play that.. its not exactly what u wanted , but a work around..
another thing thats cool is setting the door locks..
i have my gx lock all doors when i move the gear shifter out of park.. and unlock all doors when the shifter is in park
works wonders
The side view mirrors tilt downward in REVERSE so you can see the curb while backing into a parking space..
Originally Posted by et415
I just got a 2004 in Dec. My side mirrors don't tilt in reverse. Is this an option?
Make sure the mirror switch is set to the left or right side. If it's in the middle, the mirrors won't tilt in reverse.
So this definitely qualified for this string....
works wonders
works wonders
Originally Posted by bareyb
How the heck do you do that?
Doors locking when you shift out of park is the default, so your GX should already do this. I'm going to have them switch the default so that it locks when the car goes faster than 15 mph (instead of when shifting out of park) (so if I go get the car and drive slowly to the door, I don't have to unlock the doors again).
My dealer (Longo Lexus in El Monte, CA) has a sheet that has all the different customization options. You should ask your dealer.
It's in the owners manual, but when I tried to program the locks, it didn't work. Next week I'm going to go into the dealer for my complimentary 30 day service. They're supposed to do all the customization at this service.
These are some of the functions that you can have Lexus changes (formally C-BEST, now called LPS) for free (at least the first time).
However, these are also the only ones that a user can program themselves. It does work as I have done them all.
Check the manual, but basically it involves getting in, shutting the door, put hand brake on, then put the Shift lever in P or in N (depending on which function you are doing) and then turn key to ON (not Start) and then with 10seconds hold the lock side (or unlock side again depending on the function you are changing) of the driver side door lock switch for 5 seconds and releasing. The doors will then lock and unlock once by themselves to acknowledge the change after you release.
BTW, the functions are NOT mutually exclusive. That is you can have the doors lock when shifted out of Park AND lock when you go over 13mph. Similary you can have the doors unlock when you open the drivers door within 10 seconds of taking the key out AND when you shift to P.
Found this via latest Lexus Newsletter email: http://www.lexus.com/home/faqs/lps.html
PDF format of the LPS options can be downloaded.
Enjoy,
Enjoy,
