Lowering the GX
Lowering the GX
I read with interest the article on the TraiLex which discusses raising the front end of the GX. (article below) I was wondering if cutting an inch off of the 5/8 diameter shaft, then doing the same operation as discussed below, would accomplish what I want to do, which is to lower the GX an inch or so. Any thoughts ??
~ Cap
<< Here is our 3-inch front lift kit. The stock Lexus front coil over shocks feature adjustable damping and are easily up to controlling 33-inch tires. Stock tires measure 30.5. The bottom mounting eye is part of a 2-inch-long, 5/8-inch-diameter shaft that extends to the shock body. We simply cut the shaft in two, did some careful measuring, and then machined a 2 1/4-inch spacer which press fit into the two stubs. We then welded the assembly into a solid piece and voila!, 3 inches of lift at the axle hub. The rear lift is already built in with the GX470's air-ride rear suspension, which, on its "high" setting, lifts the vehicle 3 inches. With our 3-inch front lift, the rig sits level and fits 33s with no problem. >>
~ Cap
frank69m
GX - 2nd Gen (2010-2023)
14
03-19-13 11:29 AM
