list of TSB
list of TSB
Can someone out there post all the information in the following TSBs. I am getting ready to go to the dealer for my 10k service and I want to have all of the information.
1. Drivline thump TSB
2. Vibration TSB
3. Sulfur TSB
4. AC TSB
5. Outsite temperature wrong TSB
Thank you for your time.
2. Vibration TSB
3. Sulfur TSB
4. AC TSB
https://www.clublexus.com/forums/sea...by=&sortorder=
most of em are all there
if not http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm
lists em all
lists em all
Make : LEXUS Model : GX470 Year : 2003
Service Bulletin Num : 00404 Date of Bulletin: APR 26, 2004
NHTSA Item Number: 10007092
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary: EXCESSIVE SULFUR DIOXIDE ODOR. INCLUDING THE MY2004 LEXUS GX 470. *TT
Service Bulletin Num : 00104 Date of Bulletin: APR 13, 2004
NHTSA Item Number: 10007096
Component: POWER TRAINRIVELINERIVESHAFT
Summary: REAR DRIVESHAFT CLUNK/THUMP NOISE. INCLUDING MY2004 LEXUS GX 470. *TT
Service Bulletin Num : 00104 Date of Bulletin: MAR 03, 2004
NHTSA Item Number: 10006549
Component: ELECTRICAL SYSTEM
Summary: JUMP STARTING VEHICLES EQUIPPED WITH CRANK HOLD FEATURE. *TT
Service Bulletin Num : 00404 Date of Bulletin: FEB 19, 2004
NHTSA Item Number: 10006194
Component: STEERING
Summary: STEERING VIBRATION AND DRIVELINE VIBRATION/ DRONE. ALSO INCLUDING MODEL 2004 LEXUS GX 470. *MR
Service Bulletin Num : 00104 Date of Bulletin: JAN 09, 2004
NHTSA Item Number: 10005740
Component: EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Summary: AIR CONDITIONING (A/C) PERFORMANCE IMPROVEMENT. EXPERIENCING LOW COOLING EFFECT FROM THE A/C SYSTEM WHEN DRIVING IN HIGH TEMPERATURE AREAS. 2004 GX470 ALSO INCLUDED. *TT
Service Bulletin Num : 00303 Date of Bulletin: DEC 23, 2003
NHTSA Item Number: 10005746
Summary: MALFUNCTION INDICATOR LAMP (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P0441, P0442 AND/OR P0446. 2004 GX470 ALSO INCLUDED. *TT
Service Bulletin Num : 01503 Date of Bulletin: NOV 26, 2003
NHTSA Item Number: 10005259
Summary: OUTSIDE TEMPERATURE DISPLAY INACCURATE. *TT
Service Bulletin Num : 00803 Date of Bulletin: OCT 14, 2003
NHTSA Item Number: 10004500
Component: STRUCTURE:BODY
Summary: REAR CONSOLE BOX DOOR MAY NOT STAY CLOSED. *TT
Service Bulletin Num : BO00503 Date of Bulletin: SEP 08, 2003
NHTSA Item Number: 10003967
Component: STRUCTURE:BODY:HOOD
Summary: HOOD DIFFICULT TO OPEN. *TT
Service Bulletin Num : BO00603 Date of Bulletin: SEP 08, 2003
NHTSA Item Number: 10003968
Component: VISIBILITY:POWER WINDOW DEVICES AND CONTROLSSummary:
REAR DOOR POWER WINDOW REGULATOR SWITCH ASSEMBLY LOOSE. *TT
Service Bulletin Num : EL01103 Date of Bulletin: SEP 03, 2003
NHTSA Item Number: 10003966
Summary: POWER WINDOW AUTO FEATURE MALFUNCTION. *TT
Service Bulletin Num : SU00103 Date of Bulletin: AUG 28, 2003
NHTSA Item Number: 10003575
Component: SUSPENSION:FRONT
Summary: SQUEAK NOISE FROM THE LOWER FRONT AREA OF THE VEHICLE OVER SHARP IMPACT TYPE BUMPS. *TT
Service Bulletin Num : EL01003 Date of Bulletin: AUG 25, 2003
NHTSA Item Number: 10003574
Summary: LEXUS LINK SYSTEM ERROR DETECTED. *TT
Service Bulletin Num : NV00703 Date of Bulletin: AUG 11, 2003
NHTSA Item Number: 10003572
Component: STRUCTURE:BODYOOR
Summary: GROAN OR GRINDING NOISE FROM THE BACK DOOR STAY WHEN OPENING AND CLOSING THE DOOR. *TT
Service Bulletin Num : 3LF Date of Bulletin: JUL 24, 2003
NHTSA Item Number: 10003487
Component: VEHICLE SPEED CONTROL
Summary: SPECIAL SERVICE CAMPAIGN 3LF TO INSPECT AND/OR REPLACE THE THROTTLE BODY ASSEMBLY. AN ELECTRICAL CONTACT IN THE THROTTLE BODY MOTOR MAY MALFUNCTION CAUSING THE MALFUNCTION INDICATOR LIGHT (MIL) TO ILLUMINATE ON THE DASH AND THE ENGINE CONTROL MODULE (ECM) TO STORE A TROUBLE CODE AND PLACE THE VEHICLE INTO A LIMP HOME MODE. *TT
Service Bulletin Num : BO00403 Date of Bulletin: JUN 12, 2003
NHTSA Item Number: 10003367
Component: SEATS
Summary: FRONT SEAT TRACK LOOSE FEELING DUE TO CARPET INSTALLATION. *TT
Service Bulletin Num : AU00203 Date of Bulletin: JUN 06, 2003
NHTSA Item Number: 10003369
Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
Summary: REAR SEAT AUDIO SYSTEM AND CD CHANGER TROUBLESHOOTING. *TT
Service Bulletin Num : 00403 Date of Bulletin: MAY 12, 2003
NHTSA Item Number: 10002011
Summary: WIRELESS HEADPHONE UNEXPECTEDLY TURNS OFF DURING LOW TEMPERATURE OPERATION. *TT *JB
Service Bulletin Num : 00303 Date of Bulletin: MAY 07, 2003
NHTSA Item Number: 10002018
Summary: REAR LICENSE PLATE INSTALLATION. *TT
Service Bulletin Num : 00303 Date of Bulletin: APR 25, 2003
NHTSA Item Number: 10001538
Component: SEATS
Summary: FRONT SEAT TRACK SQUEAK/CREAK NOISE. *TT
Service Bulletin Num : 00203 Date of Bulletin: APR 17, 2003
NHTSA Item Number: 10001536
Summary: ENGINE COVER BUZZING NOISE. *TT
Service Bulletin Num : 3LA Date of Bulletin: MAR 27, 2003
NHTSA Item Number: 10001317
Component: EQUIPMENT:OTHER:LABELS
Summary:
CERTIFICATION REGULATION LABEL REPLACEMENT. *TT
Service Bulletin Num : 3LC Date of Bulletin: MAR 27, 2003
NHTSA Item Number: 10001319
Component: SUSPENSION:REAR:SPRINGS:AIR SUSPENSION SYSTEM
Summary: SPECIAL SERVICE CAMPAIGN - REAR AIR SUSPENSION. *TT
Service Bulletin Num : 00203 Date of Bulletin: MAR 10, 2003
NHTSA Item Number: 10001313
Summary: SERVICE MAINTENANCE REMINDER LIGHT RESET PROCEDURE. *TT
Service Bulletin Num : 00103 Date of Bulletin: MAR 10, 2003
NHTSA Item Number: 10001314
Component: SEATS
Summary: FRONT SEAT SQUEAK / THIRD ROW SEAT RATTLE. *TT
Service Bulletin Num : 3LB Date of Bulletin: MAR 07, 2003
NHTSA Item Number: 10001318
Component: SEATS:MID/REAR ASSEMBLY
Summary: SPECIAL SERVICE CAMPAIGN - MIDDLE ROW SEAT LOCK. *TT
Service Bulletin Num : 00103 Date of Bulletin: FEB 28, 2003
NHTSA Item Number: 10001310
Summary: A750 TRANSMISSION SOLENOID IDENTIFICATION. *TT
Service Bulletin Num : 00203 Date of Bulletin: FEB 26, 2003
NHTSA Item Number: 10001309
Component: SEAT BELTS
Summary: SEAT BELT EXTENDER. CERTAIN MODELS INCLUDING THE 2004 RX 330. *TT
Service Bulletin Num : 00501 Date of Bulletin: JAN 09, 2003
NHTSA Item Number: 10001049
Summary: DIAGNOSTIC TESTER IMMOBILIZER FUNCTIONS. *TT
Service Bulletin Num : 121602 Date of Bulletin: DEC 16, 2002
NHTSA Item Number: 10000663
Summary: INSPECTION AND REPLACEMENT OF GX470 TOWING BALL MOUNTS. *TT
Component: STEERING
Component: SEATS
Component: SEATS
Summary:
Component: SEATS
mstrsltr
GX - 1st Gen (2004-2009)
17
11-21-16 03:16 PM
