GX470 H11 Xenondepot kit installed DIY guide
Old 10-22-13, 07:02 AM
  #481
XenonDepot
Former Sponsor
XenonDepot's Avatar
Hi,
You're looking for a kit for the GX?
Steve
Old 10-22-13, 04:12 PM
  #482
zeeshan66
zeeshan66's Avatar
yesir I've got a 2003. Looking for the brightest spare no expense kit
Old 10-23-13, 07:19 AM
  #483
XenonDepot
Former Sponsor
XenonDepot's Avatar
Hi,
The GX uses an h11 bulb for the low beams, meaning that you would need to order an h11 HID conversion kit. Most people on this board go with a 4300k HID kit (color temperature) for the brightest, and most functional light output. The higher you go in terms of color temperature, the less actual useable light output you emit.
If you want the best, I would suggest going with the Xtreme HID kit w/ Philips capsules.
You would need to select the "H11" fitment.
Make sure to use coupon code "CL" upon checkout to save $25 on your order.
Steve
Old 10-23-13, 07:13 PM
  #484
zeeshan66
zeeshan66's Avatar
thanks for the quick reply. I'm most likely going to go with the 4300k HID kit because of the color. Is there a PDF or guide for install? Is it a DIY job (i'm not a DIY person per say) lol
Old 10-23-13, 07:40 PM
  #485
RCsGX
RCsGX's Avatar
Check on page 1 of this very thread, post 1-11.
Old 10-24-13, 08:33 AM
  #486
zeeshan66
zeeshan66's Avatar
I appreciate you not flaming me as i should of been
Old 10-24-13, 08:59 AM
  #487
XenonDepot
Former Sponsor
XenonDepot's Avatar
I would also be more than happy to give you a call to discuss the installation - if you would like me to.
Steve
Old 10-24-13, 11:27 AM
  #488
RCsGX
RCsGX's Avatar
We've all had one of those... moments.
Old 10-24-13, 09:13 PM
  #489
bobinwash
bobinwash's Avatar
Steve, just pm'd you on some fogs for my GX. Great info in this thread
Old 10-25-13, 07:26 AM
  #490
XenonDepot
Former Sponsor
XenonDepot's Avatar
Just replied
Old 10-25-13, 10:13 AM
  #491
RCsGX
RCsGX's Avatar
Just curious...why are you wanting to use hid fogs?
Old 10-25-13, 11:02 AM
  #492
redrocks
redrocks's Avatar
LEDs in the fog lights might be a better option.
Old 10-25-13, 01:53 PM
  #493
XenonDepot
Former Sponsor
XenonDepot's Avatar
LEDs in the fogs would be purely cosmetic (in my opinion).
Hope all is well redrocks!!
Old 10-25-13, 02:00 PM
  #494
RCsGX
RCsGX's Avatar
Depends on what you're after, that's why I asked.
If you want to color match your HIDs, yes a pnp LED would probably be a better and cheaper option. To use a pnp LED for a useable on/off road light source no way. The only way to get that would be to build you own high powered LED array or use a OEM array and do a fog light retro, which I doubt anyone here would care to do because of the time and cost but if I'm wrong here's a nice OEM BMW 650 LED fog light that you could use the guts from.
Old 10-25-13, 02:44 PM
  #495
redrocks
redrocks's Avatar
Thanks Steve!
Hope you're doing well too!
Quick Reply: GX470 H11 Xenondepot kit installed DIY guide
