Driveline "clunk" to hopefully be fixed
I emailed our service manager with the driveshaft fix you guys have talked about to fix the driveline "clunk." He said our part has come in and is waiting for us to bring the car in for the 10k service to be installed. Hopefully this will fix it
PS- should we worry about replacing something as major as a driveshaft?
About three months ago, We sat down and talk with Lexus engineers. They show us how to fix the problem. That was back then when I was working at the dealership. I have access to the TSB. How is the A/C working for your guys? It's the winter now, wait until the summer is here. It will get worse.
JPI
JPI
Originally posted by tetra7
So how do you know this will fix the problem? Since when did they implement this fix?
I don't have the part # on this. But It's the drive shaft and they will have to use a special grease to lube it up for the installation. A/C problem, The A/C just shut down if you are sitting in traffic. Problem: not getting enough air flow through the condenser. They put another fan in there to help it out a little bit. I will keep you guys updated.
JPI
JPI
JPI
JPI
The A/C problem described above is for 03 or 04?
