2007 gs 350 Good buy?
Old 05-21-15, 06:40 AM
travGS350
travGS350's Avatar
Default 2007 gs 350 Good buy?
I am looking to buy a 2007 Lexus gs 350 AWD. It currently has 59,000 miles and the carfax is clean. The 60,000 mile maintenance service will be performed before I buy it but was wondering if $17,600 is a good price. I have no experience with Lexus and am wondering if the vehicle will be reliable and if $17,600 is a reasonable price. Any advice would be great!
Old 05-21-15, 08:35 AM
gr8fulRed
gr8fulRed's Avatar
here is a link to NADA values....but you may need to adjust "trim level"/options (ML stereo, Nav, etc) and use your local zip code to get more accurate values.
http://www.nadaguides.com/Cars/2007/...350-AWD/Values
Old 05-21-15, 10:25 AM
travGS350
travGS350's Avatar
Thanks for the link. I'm hoping to get it out on the highway and test drive it tomorrow. Is there any common problems with this year, make, and model that I should look out for?
Old 05-21-15, 11:11 AM
ibidu1
ibidu1's Avatar
I would replace water pump and flush the cooling system, 2007 are great with no known issues. But its AWD if you wanted to lower it, you will get vibrations.
Also in 2008 they updated the 3GS with a slightly newer front and new electronics.
Old 05-21-15, 01:08 PM
jdmek998
jdmek998's Avatar
So far mine has been great!
Old 05-21-15, 07:15 PM
NickTee
NickTee's Avatar
Check the updates on the 2008, you may find you'd prefer that one.
Old 05-21-15, 08:21 PM
xbladex00
xbladex00's Avatar
have an 2007 GS 350 AWD check to see if the fresh air mode works! if it ticks in fresh air mode then the door to the cabin filter is broken!!! also the rear calipers are known to seize so if the pedal goes to the floor then they're most likely seized... Dunt know any other symptons other than that... The will naturally vibrate regardless i think... well mine does but take the vibrating with a grain a salt since my car hasn't been looked after that well...
I'm not sure what else to tell you but inspect the tires, rims, rotors (see if they're warped) run your nail on it if it isnt smooth then theyre warped... look for scratches and dents on the body.... Most likely there will be swirl scratches from car washes....
If you point it out these things you could probably hassle him for less
Old 05-21-15, 09:17 PM
NickTee
NickTee's Avatar
Check all the panels for the VIN sticker to see if they're original or if it's been in a wreck. Doors, hood, and trunk are easy to check. The front fenders require you to move the trim and/or the hood seals to look.
https://www.clublexus.com/forums/gs-...fferences.html
That's the major changes.
Old 05-26-15, 08:29 PM
travGS350
travGS350's Avatar
Thanks for the advice. I purchased the 2007 Lexus gs 350 AWD with 59,000 miles this past weekend. I am still breaking it in and have not been disappointed. The acceleration is much better than the Infiniti G37x I test drove. It is also much smoother. I am happy to say that I am much pleased thus far that I went with the Lexus. Thanks again for all the advice!
leisinjp
03-11-15 11:13 AM
ksan
06-14-13 12:51 PM
GS4TEK
03-28-13 09:58 AM
Mariusz232
10-23-11 09:28 AM
Mariusz232
10-21-11 09:28 PM
Quick Reply: 2007 gs 350 Good buy?
