Headlight / fog light one works and one doesnt. Odd?
Old 05-10-15, 10:08 PM
xmike714x
xmike714x's Avatar
Default Headlight / fog light one works and one doesnt. Odd?
So I installed HID fog lights on my car and one day, the left side stopped working. I thought the bulb burnt out and just left it there. So now, i am just running with just my right fog light on with my headlights.
Well a couple of days ago, my left headlight goes out and my left fog light now works. Something to do with wiring? Anyone know how to diagnose this?
Old 05-11-15, 12:51 PM
XxGoKoUxX
XxGoKoUxX's Avatar
If you do a quick search, you'll find that no one can tell you what it is unless you diagnose it yourself.
You can start off by replacing the bulbs and then move on to ballasts.
FYI: These cars don't like cheap bulbs so use reputable HID bulbs in your car.
GL
Old 05-11-15, 04:35 PM
sha4000
sha4000's Avatar
Try switching the bulbs from side to side but I'll put my money on the wiring.
Old 05-11-15, 05:23 PM
SoCal_450h
SoCal_450h's Avatar
most likely cheap bulbs...
Old 05-11-15, 08:17 PM
xmike714x
xmike714x's Avatar
The HID bulbs are Philips Ultinons.
So on the driver side, if the HID goes out, the fog light works...then at times, the HID drive light would work, and the driver fog would work. that is what is happening to me. its like one or the other.
Old 05-12-15, 08:11 PM
rl9010
rl9010's Avatar
Have you checked your battery? Maybe it is weak? I know as I was working on my car with all lights on, all of the sudden the fog light turned off. Then the passenger side headlight turned off. I went to go start the car and found the battery to be weak. Started the car, drove around to charge it up and the issue went away.
What HID kit did you use for your fog lights? Try replacing the fog lamp with normal halogen bulbs to see if it still occurs. Check the connection at the bulbs for all lights. If that doesn't work its time to use a multimeter and check the wiring. Well, that's how I would diagnose it.
Old 05-14-15, 01:00 PM
XenonDepot
Former Sponsor
XenonDepot's Avatar
xmike714x - Are you certain that the D2S Ultinon is genuine? I would suggest swapping components also to see if you can isolate what is causing the issue.
Are you using a relay harness, or are you powering the ballasts directly from the OE wiring?
ultimate
Performance & Maintenance
11-18-18 05:31 PM
HotShotEng
02-25-12 12:07 PM
LostS0ck
01-13-12 01:09 PM
Shank2117
10-08-08 04:59 AM
awol707
01-01-08 02:32 PM
Quick Reply: Headlight / fog light one works and one doesnt. Odd?
