need some help on brakes GS300
hello, i would like to know if the gs300 2009 (third gen) use the same disc brake and pads that the gs350, because i need to replace it and i only have ebay to buy it.
regards,
Giovanni.
regards,
Giovanni.
Im pretty sure 06 was the last year of the gs 300, 09 would be a gs350 which has much larger brakes then the 06
ML Audio,
rear side airbags (total of 10)
VDIM/VSC cut-off
trunk closer
etc...
MODEL: GRS190L-BETQHW
ENGINE: 3GR-FSE 2995ML
FRAME NUMBER: JTHBH96S995062249
COLOR: 1F2; TRIM: LA20; PLANT: ***
TRANS./AXLE A960E BO4A 2109
im from Chile.
regards,
Giovanni.
im from Chile.
regards,
Giovanni.
That's weird the 8th digit of the Vin is S which is the 3.0 v6 but from what I've found is 09 should have the 3.5 v6. If I had to guess I'd say you have the same brakes as an 06, Try looking at your caliper to determine if it's the larger 4 piston gs350 brakes or the smaller 2 piston gs300 brakes
[Imgur](https://i.imgur.com/lzRnD9n.jpg?1)
and what about the rotors? the gs350 2007-2011 use the same size?
what about this?
http://www.ebay.com/itm/07-08-GS350-2WD-Front-Brake-Pads-and-Rotors-kit-set-kit-NEW-genuine-Lexus-OEM-/191158325111?fits=Model%3AGS350&hash=item2c81ec8f77&vxp=mtr
or:
http://www.ebay.com/itm/LEXUS-GS350-IS350-GS450H-GS460-FRONT-OEM-TOYOTA-BRAKE-ROTORS-PAD-SET-/390421521380?hash=item5ae6efa3e4&vxp=mtr
thanks a lot for your help!
NO_WUR_E
01-29-08 02:41 AM
