DIY- IS350 steering wheel swap
Old 04-30-15, 05:48 PM
sprtn131
sprtn131's Avatar
Default DIY- IS350 steering wheel swap
Hey everyone, this is my first, Diy thread so I'll do my best...ask away if I missed anything.
What you'll need: ratchet wrench, 10mm socket, 19mm socket, 6 in extension Philips screwdriver, T30 torx driver, wire cutters, wire strippers, heat shrink tubing, electrical tape, 22 Guage wire(preferably 2 different colors) a soldering iron, solder, and some mad skills
Before
After
Step 1: Steer the wheels straight forward, disconnect the battery
(Very important, you don't want your airbag going off) I recommend doing this with the key on, that will make it easier to remove some of the trim.
Step 2: remove the steering wheel. If your not sure how, check out utube, there's some good videos that detail what to do. Be careful not to let the clocksping move when the wheel is off, otherwise it will get damaged and your airbag light will be on.
Step 3: remove the two Philips screws and trim piece behind the steering wheel. This can be tricky, use a plastic interior tool to separate. It opens like a clamshell.
Step 4: remove all trim shown here
Including the center console, and the plastic door piece at your left foot.
From here out it gets real tricky.
Step 5: remove the wire from the cruise control switch out of your old wheel and de pin it
Now is when you'll want to make your new wires for the paddles, I used red and green. Give yourself about 4 feet, make sure to leave enough slack for the telescoping feature.
Disconnect this plug
Cut the purple wire
Splice in your red wire
Take your green wire and insert it into the open spot next to the yellow wire
Step 6: Disconnect this plug
Cut the yellow and orange wires
Run your red and green wires underneath the dash, tuck them out of the way so they won't be hanging around, I used zip ties. Then splice like so
Tape up each one with electrical tape and plug back in
Step 7: Cut the pink wire on the new wheels connector
Splice in your new pin and plug it into this slot on the new cruise control plug
Step 8: reinstall all trim, line up the steering wheel as strait as possible, you may need an alignment if it's crooked. reconnect the battery.
Step 9: have fun
Old 04-30-15, 10:35 PM
BinaryJay
BinaryJay's Avatar
Seems like a downgrade to me, but great thread and could be very useful for anybody that needs to do anything with their wheel.
Added to the DIY sticky:
https://www.clublexus.com/forums/gs-...tart-here.html
Old 05-01-15, 04:21 AM
uberEJ
uberEJ's Avatar
nice! kind of weird i have to manually click open some of the images but great work! now i just hope the 4gs steering wheel will be similar.
step 6 where are those plugs located? in the center console?
Old 05-01-15, 05:34 AM
Stoodo
Stoodo's Avatar
Do the paddle shifters works?
Old 05-01-15, 05:35 AM
sprtn131
sprtn131's Avatar
Left kick panel
Old 05-01-15, 05:43 AM
sprtn131
sprtn131's Avatar
They work perfectly
Old 05-01-15, 05:46 AM
sprtn131
sprtn131's Avatar
It's definitely not for everyone, I did a full wood delete and wanted something a bit sportier
Old 05-01-15, 06:10 AM
uberEJ
uberEJ's Avatar
which is why i want to try it with the new gen wheels. a little bit sportier.
so there was no actual wires going to the shift lever? im curious where you found the pinouts for it.
once again bro thanks for posting this up.
Old 05-01-15, 11:42 AM
sprtn131
sprtn131's Avatar
Not really to the shifter more to the transmission.
Had to use an ohm meter, and I got a kick *** wire diagram from my buddy Mr Blageo, happy to help. And good luck with the 4gs swap, would love to see pics
Old 05-01-15, 01:23 PM
BinaryJay
BinaryJay's Avatar
But serious question, you must actually use the "manual" shifting to have gone through all the trouble? I have always found it the most useless feature of the car myself. =)
Old 05-01-15, 02:11 PM
worker
worker's Avatar
Agree. Just flip the switch to PWD and floor it. In PWD, just touch the brake and it down shift for you. And the most fun part is floor it again, the gear already down shifted so it just pull.
Don't need all that manual shift.
Old 05-02-15, 08:36 AM
SoCal_450h
SoCal_450h's Avatar
where are the phone pick up and hang up button? does it work?
Old 05-03-15, 05:23 PM
verly6565
verly6565's Avatar
has anyone tried it
Old 05-05-15, 05:20 AM
IcyBishop
IcyBishop's Avatar
Very intrigued by having paddle shifters in the car!
Also, kudos for using shrink tubing and doing things the "right" way
Old 05-05-15, 11:25 AM
sprtn131
sprtn131's Avatar
That pic shows the dead button, what I didn't show was how i modified it to make it work until I could get the actual one
End result
Quick Reply: DIY- IS350 steering wheel swap
