GS430 oil leak help!
Old 04-26-15, 04:26 PM
justYnG
justYnG's Avatar
Default GS430 oil leak help!
for starters i hardly drive my gs430 and ill put it this way. its almost been a year and i still havent put 5k miles on the vehicle. back to the matter at hand. im starting to see an oil leak in my driveway from this vehicle. im unsure exactly where its coming from. it could be from the valve cover or the cam seal (assuming that is what it is called). has anyone else had this issue? if so, is it hard to replace? i have extensive knowledge on vehicle maintenance, when it comes to honda... pictures below.
the leak is above the alternator that is why i think its the valve cover and or the cam seal (if thats what it is)
Old 04-26-15, 04:36 PM
XxGoKoUxX
XxGoKoUxX's Avatar
Did you try feeling up against the valve cover gasket area?
Old 04-26-15, 04:49 PM
Anh85
Anh85's Avatar
Wipe it down and look at it again in a couple of days. It does look like the valve cover gasket
Old 04-26-15, 04:55 PM
justYnG
justYnG's Avatar
no i havent the motor was still hot
justYnG
justYnG's Avatar
i hope it is. have you done the job before? i hope its easier than my is300 (in which i still need to do).
rerose
01-25-18 11:23 PM
niteridrIS
IS - 1st Gen (2001-2005)
09-19-17 10:51 AM
mate01
02-20-16 02:09 PM
UDel
03-12-15 06:35 PM
alvin
04-10-02 08:14 PM
Quick Reply: GS430 oil leak help!
