Need Help for choosing wheel
I am trying to change my wheel, and I fould these wheel from C/L.
Please help me with the fitment,,
20x10 275/35/20 Rears 20x8.5 245/40/20 Fronts.
20x8.5 5x114.3 35et 73 hub/20x10 5x114.3 43et 73 hub
4inch lip Rear/ 2.5 inch lip fronts
This is the description,
Please advise me,,, If these wheel fit on my 06 GS430.
And one more stupid question....
I dont understand why people use different height tire... (35/ 40)
Thank you,,
Thank you,,
The second number is a % of the first number. So since you have staggered tire sizes, you would need a different aspect ratio to get roughly the same height.
Those tire sizes are WAY too big. You want to keep it under 3% bigger than stock tire size. Most people here run 245/35/20 and 275/30/20. However the front is slightly over 3% and therefore, "overspec", If you have particular rough roads to drive on like the streets of LA the extra cushion would be nice, even if you may rub slightly. I personally would go 235/35/20 and 275/30/20 which are much closer to the same size.
I8ABMR
10-03-07 12:13 AM
