AWD woes. RWD conversion?
Old 03-26-15, 09:48 AM
Skylar978
Skylar978's Avatar
Default AWD woes. RWD conversion?
I'm starting to get annoyed by the awd vibration. I know evos, subarus, and various other makes have converted their awd cars to rwd fairly easily. Is the 3gs a different beast altogether? I'm not too familiar with what's involved, but would like to know if it's fairly easy and if the cost to do this outweighs the solution.
Anybody?
Old 03-26-15, 09:53 AM
GS350Lexus
GS350Lexus's Avatar
I would assume just remove the front axels and you are done. Never seen anyone convert to rwd here, and honestly it would probably be worth selling your awd and getting rwd. Rwd suspension is also lower, the car is lighter also.
Old 03-26-15, 10:19 AM
uberEJ
uberEJ's Avatar
you can't just remove the axles and drive it as rwd. it would cause the differential to go boom lol. our gs if im correct have a 30/70 tq split.
just get a rwd trans, driveshaft, front hub assemblies, and ecu and install. but at this point you might as well go 2jz and deal with wiring. lol
there are some other cars that have wobble after lowering but 3rd party companies have created axle spacers to eliminate that for those cars. for our cars no successful attempt has been made unfortunately. i was able to minimize vibration and wobbles by using urethane control arm mounts and its helped it pretty well. my vibrations and wobble arent noticeable much.
Old 03-26-15, 10:23 AM
alredxiii
alredxiii's Avatar
Default 4wd
In retrospect if you are going to mod and lower do not get a 4wd
Old 03-26-15, 10:42 AM
uberEJ
uberEJ's Avatar
yeah this ^^^^
or go bagged.
Old 03-26-15, 10:45 AM
Gotcha350
Gotcha350's Avatar
Sell and buy a RWD....problem solved the easy way...
The luxury of not needing AWD is so sweet...
Old 03-26-15, 10:49 AM
L's TLS
L's TLS's Avatar
Exact reason why I got RWD, cant deal with wobbles on a daily
Old 03-26-15, 04:59 PM
Steve2424
Steve2424's Avatar
So it looks like the slight vibration and wobble are a plague of the 3GS AWD. I initially thought I had uneven tires or even a bent rim, but from reading here and just driving the car over different surfaces it became clearer it was the way the drivetrain system was designed for this car. Kind of sucks given how much else this car does right, and how the like of cars like subarus, infinitis and acura awd systems don't even let you know it's there.
Old 03-26-15, 05:23 PM
jmack2688
jmack2688's Avatar
I've seen someone on this forum post about custom front axles. Is that an option to solve the wobbles/vibration?
Old 03-26-15, 05:30 PM
LexusLive
LexusLive's Avatar
I **** and moan almost daily about my 300 GS, but I gotta say I've never experienced these symptoms.
Old 03-26-15, 09:22 PM
xbladex00
xbladex00's Avatar
My Gs350 has very little noticeable vibration... It only vibrates alot when the AC is on.... I think someone said in a different thread that a engine mounting could be broken and that could be causing the bad vibrations.....
Old 03-27-15, 04:33 AM
uberEJ
uberEJ's Avatar
Originally Posted by jmack2688
I've seen f someone on this forum post about custom front axles. Is that an option to solve the wobbles/vibration?
yes its possible but not confirmed. after i finish my air ride set up im going to get some custom axles made if its worth the expense i will post on my build thread when i do so but that wont be till summer... getting the axles i mean.
Old 03-27-15, 04:21 PM
jmack2688
jmack2688's Avatar
Hope it works out, I'll be trying the spacers on the front axles or putting quarter half metal between the engine mounts
Old 03-31-15, 11:41 AM
Skylar978
Skylar978's Avatar
I have been inquiring at a few different places for custom axles with no Luck.. I tried to contact RAXLES and they said they dont have a solution for us at this point.
Might I add that I am maxed out on my ride height in the front on my Suspension and rears have another 2-3 inches which would lay my frame before it would even max out of adjustability.
For the record, I did not experience any weird vibrations prior to me lowering my car, So those of you who are not lowered and are experiencing this have a slight different issue from me.
Thought about going BAGS, but not sure if I want to invest in a bag setup since I have a few other goodies coming from Japan and a Business start up that needs most of my attention.
I plan to 2jZ it eventually when it is more feasible.
Old 04-01-15, 02:50 AM
IXI187IXI
IXI187IXI's Avatar
i dont have any issues.....
Quick Reply: AWD woes. RWD conversion?
