Trunk issue. Is there a fuse puller tool somewhere in the GS?
Old 02-01-15, 11:46 AM
nuck
nuck's Avatar
Default Trunk issue. Is there a fuse puller tool somewhere in the GS?
My 07 GS350 trunk won't open and it doesn't make any kind of actuation sound (not the valet button tho and disconnecting battery had no effect). I figured before I offered my wallet to the dealer I would make sure it wasn't just a fuse. I don't suppose Lexus has stashed a fuse puller somewhere on the car? I don't have one for the mini blade fuses.
Old 02-01-15, 11:53 AM
mr. tetsuo
mr. tetsuo's Avatar
Yea there is one inside fuse box in the engine bay.
Old 02-01-15, 12:02 PM
ibidu1
ibidu1's Avatar
Use a needle nose pliers instead of the fuse puller its much faster
As far as the trunk not operating theres a TSB for the fuse panel in the driver side, I believe the connections get corroded.
Old 02-01-15, 08:26 PM
nuck
nuck's Avatar
Thanks for the info guys. ibidu1 do you know if that would be the TSB for the $1800 stuck trunk fix I have read about (off warranty) or is that something else? Seems like a lot for a fuse panel
Old 02-01-15, 08:34 PM
pman6
pman6's Avatar
you know there's a keyhole for the trunk, right?
it would be a safety issue if someone got locked in the trunk and could not bypass the stupid closing mechanism
Old 02-02-15, 09:28 AM
nuck
nuck's Avatar
Default So I found the TSB but can't match part numbers
Below is from a Canadian vendor. 82730-30272 from the TSB doesn't come up. Are there different part numbers across the border?
Junction Block. .
This genuine part fits your 2007 Lexus GS350 Base 3.5L V6 Automatic .
Lexus
Stock Code 8273030274
Manufacturer Lexus
Categories Electrical, Lighting, Telematics > ELECTRICAL COMPONENTS; Electrical, Lighting, Telematics > Electrical Connectors
Assemblies ELECTRICAL COMPONENTS.
CONTROL MODULES & COMPONENTS INSTRUMENT PANEL Left. Junction block.
This product fits 12 vehicle variants.
http://www.lexuspartsdirect.ca/image...ze/8945210.jpg
Thanks for any responses.
Old 02-02-15, 12:26 PM
nuck
nuck's Avatar
N/M. The vendor confirmed the part number he has is the new one for the TSB. This is quite a bit less expensive than I feared for what seems to be a pretty common problem and Sewell is cheaper yet.
Goosesedan
08-21-20 03:24 AM
Alexbenz
02-09-17 12:55 PM
lamontp71
04-18-16 07:58 AM
Amini9
SC- 1st Gen (1992-2000)
12
01-25-09 12:41 AM
SilverLS400
07-31-02 08:42 AM
Quick Reply: Trunk issue. Is there a fuse puller tool somewhere in the GS?
