Transmission maintenance ??
Old 01-26-15, 10:16 PM
gr8fulRed
gr8fulRed's Avatar
Default Transmission maintenance ??
So..been reviewing the warranty/maintenance schedule for my 09 GS (new to Lexus and want to pick up where the previous owner left off) and am reading that Lexus doesn't call for changing out transmission fluid??! Book says it's a sealed system with no dip stick and it only calls for periodic "checking for leakage". The book stops at 150k (maintenance schedule)...just curious if anyone has had issues with these 3gen tranny's and if anyone has actually serviced theirs. Can't say that I've heard of any transmission that didn't have a maintenance schedule.
Old 01-27-15, 04:59 AM
burny
burny's Avatar
I did the GS350 tranny fluid at around 80k. Got 12 quarts out and 12 new in. Kinda tricky, but if you take your time it is not any more difficult than changing motor oil. I got almost 3 quarts at a time and refilled with new until i saw the new fluid coming out. The top off procedure is the tricky part. There are write ups on here on how to do it. Do not just measure and put same amount back in. Use the top off procedure as this fluid expands under heat and needs to be done properly.
Old 01-27-15, 08:00 AM
gr8fulRed
gr8fulRed's Avatar
great info! thanks for your input sir
Old 01-27-15, 08:02 AM
warandcar
warandcar's Avatar
toyota here in california charges $179 for a drain and fill and 289 for the flush...
Old 01-27-15, 11:30 AM
burny
burny's Avatar
Use 2 people when you do the top off. jumper 4 and 13 pin on OBD. Start car and run through a series of shifts from P,R,N,D and back up. This moves the fluid. Then put in park. Then go to D and in 6 seconds move from D to N several times to put car in operating mode. When you see the D light steady on the cluster it is time to do the overflow procedure. You have about 2-3 minutes before the D light starts to blink, meaning above operating temp. I loosened the fill bolt and had a fresh quart ready and I also loosened the internal overflow tube to save time. I had someone sitting in the car to tell me when the D light started blinking. I finished before it did.
There are write-ups on the site if you use the advanced search function and narrow to 3GS
Old 01-28-15, 05:10 AM
sam12345
sam12345's Avatar
Lexus was not persuing perfection when they left the dipstick off.
silver250
08-13-21 02:32 PM
chadb5646
01-29-11 12:03 PM
LazyAlex
Performance
12-16-06 10:32 AM
Bobk528
RX - 1st Gen (1999-2003)
16
09-26-05 07:34 PM
gapxguy
Maintenance
18
04-08-05 08:27 AM
Quick Reply: Transmission maintenance ??
